I am looking for an efficient method to change the text font in the interactive handbook to the new default Arial.
A neat solution would be to write a batch conversion script. However, this would cost me some hours of writing and testing. Therefore, it might be an option to just select all (Ctrl-A) and then select Arial. It seems that this affects text regions only. Compared to the required manual re-formatting (removal of spurious line breaks etc) this would be just a few clicks.
My question is: can this be recommended? Or do I have to expect silent Arial formatting of math regions which might pop up in later versions? That would be very bad. If at all, I would change math font to Times New Roman, as in standard math typesetting.
Martin |
