Offline Ale16595
#1 Posted : 10 December 2019 16:32:25(UTC)
Ale16595
Hello everybody.
I can't understand why the phi function does not compare in the graph.
This function is the derivative of the phi function that instead appears in the graph.
Someone could help me please?
Thanks in advance
this is the file… Derivate.sm (23kb) downloaded 19 time(s).
#2 Posted : 10 December 2019 18:31:00(UTC)
1. your φ(t) plots correct
2. The Smath derivative operator works on derivative rules.
3. The φ(t) is too much a monkey business for derivative rules.
4. Rescue via transit infinitesimal analysis.
5. Your constrain in plot argument is obsolete since if/otherwise
was introduced by Davide from f(x) menu "cases".
Derivate (1 doctored).sm (25kb) downloaded 20 time(s).
Offline Ale16595
#3 Posted : 10 December 2019 20:36:26(UTC)
Ale16595
Thanks for the reply, I solved this problem.
Now, however, an error appears that does not make me draw a graph.
the error says: "The result is higher than the maximum positive value allowed"
what does it mean?
curvatura.sm (49kb) downloaded 17 time(s).
#4 Posted : 10 December 2019 23:30:44(UTC)
what does it mean?
... doctored version works top2bottom
1. Remember λ(x) as used
2. More problem(s) ... return the doctored version.
3. Delete all the black
curvatura (1 doctored).sm (54kb) downloaded 19 time(s).
Offline Razonar
#5 Posted : 11 December 2019 00:39:51(UTC)
Razonar
Uruguay
Was thanked: 830 time(s) in 526 post(s)
what does it mean?
Hi. Means that' you have divide by zero or something other invalid operation. You must to avoid that for plots with restrictions in the ranges, or with try ... on error in a routine for range plots. Attached have this second option.
curvatura - moto v2.sm (44kb) downloaded 19 time(s).
curvatura - moto v2.pdf (372kb) downloaded 15 time(s).
on 11/12/2019(UTC)
Offline Razonar
#6 Posted : 11 December 2019 07:38:57(UTC)
Razonar
Uruguay
This technique enable the view of symbolics.
curvatura - moto v3.pdf (461kb) downloaded 25 time(s).
curvatura - moto v3.sm (1,148kb) downloaded 21 time(s).
on 11/12/2019(UTC)
Similar Topics
3D Plot function help request (Questions)
by Ale_Biaso 29/11/2023 13:02:54(UTC)
Unable to plot function using vectors (Bugs & Problems)
by Banan 09/07/2018 11:24:02(UTC)
2D Plot functionality and possible improvements (Questions)
by ngdev38 25/08/2010 18:18:01(UTC)
