Hello to all. I have a problem with the Smath function "dn_GearsBDF", it blocks the operation since giving me division by zero error. How can I overcome this problem? MANOVRA (con parametri moto).sm (79kb) downloaded 12 time(s).
In dn_GearsBDF(init,0,end,100,D(x,Y)) replace zero with a small positive number (say 10^-10)
Regards, Radovan |
Hi, thanks for the reply. Instead if I have an error like: "value too big or too small for an Int32", how can I solve it? Every time this error appears the program stops. MANOVRA slalom (cinematica).sm (46kb) downloaded 10 time(s).
Always separate text from image or *.sm document, as you did: can't reply quote !
Originally Posted by: Ale16595 Hi, thanks for the reply. Instead if I have an error like: "value too big or too small for an Int32", how can I solve it? Every time this error appears the program stops. MANOVRA slalom (cinematica).sm (46kb) downloaded 10 time(s). 10^10 was probably too small, you have to see, how small x can be for your derivative ψ''(x) still being defined. 0.01 works. |
... doctoring starts at red ... observe removing 10^14 at some trig [0]. lot more cleanup below ... can you write λ instead of l MANOVRA slalom (cinematica).sm (53kb) downloaded 12 time(s).
