Offline Ale16595
#1 Posted : 31 January 2020 15:46:08(UTC)
Ale16595
Hello to all.
I have a problem with the Smath function "dn_GearsBDF", it blocks the operation since giving me division by zero error.
How can I overcome this problem? MANOVRA (con parametri moto).sm (79kb) downloaded 12 time(s).
Offline omorr
#2 Posted : 31 January 2020 16:11:20(UTC)
omorr
Rank: Administration
Serbia
In dn_GearsBDF(init,0,end,100,D(x,Y)) replace zero with a small positive number (say 10^-10)
Offline Ale16595
#3 Posted : 31 January 2020 18:14:51(UTC)
Ale16595
Hi, thanks for the reply.
Instead if I have an error like: "value too big or too small for an Int32", how can I solve it?
Every time this error appears the program stops.
MANOVRA slalom (cinematica).sm (46kb) downloaded 10 time(s).
#4 Posted : 31 January 2020 18:54:54(UTC)
Always separate text from image or *.sm document,
as you did: can't reply quote !
#5 Posted : 31 January 2020 19:12:46(UTC)
10^10 was probably too small, you have to see, how small x can be for your derivative ψ''(x) still being defined. 0.01 works.
#6 Posted : 31 January 2020 20:30:34(UTC)
... doctoring starts at red ... observe removing 10^14 at some trig [0].
lot more cleanup below ... can you write λ instead of l
MANOVRA slalom (cinematica).sm (53kb) downloaded 12 time(s).
