Hi everyone. Please, help me write the function correctly in the Smathstudio and build a graph for it. It is really to do it in a Smathstudio?
Originally Posted by: Doom Please, help me write the function correctly in the Smath Studio and build a graph for it Maybe like this ? Vo.sm (44kb) downloaded 40 time(s).
Thank you very much for your help. As I understand it, these are complex numbers. I'm not good at them yet. But, from this video (https://www.youtube.com/watch?v=cS83YUpcEsY) (time - 3:49), I realized that this is Vo*cos(wt).
Took the formula from here - (https://web.stanford.edu/class/archive/engr/engr40m.1178/reader/reader.pdf) (page - 138).
Originally Posted by: Doom As I understand it, these are complex numbers. 1. The formula exp(,) is just the exponential [decreasing in that case]. Nothing to do with complex as given. It shows the IR, IL currents. 2. The formula down far below the PDF is not associated with a circuit. Just a dead piece of curiosity. Cheers ... Jean Circle Complexn-circles.sm (11kb) downloaded 22 time(s). Circle Complex.sm (23kb) downloaded 14 time(s). Circle Complex_1.sm (66kb) downloaded 18 time(s).
... make it more classroom style. Vo.sm (49kb) downloaded 42 time(s).
Originally Posted by: Jean Giraud ... make it more classroom style. Vo.sm (49kb) downloaded 42 time(s). Thanks a lot.
