SMath Studio Forum
Questions
The value went beyond the maximum allowed positive number
Originally Posted by: Joki720 Who has faced such a problem, how can it be solved? "result above max ..." has no pertinent meaning in your project. If you attempt "roots" on the numerator only ... "Units don't match" No need to go further ... zap the units in the project.
Originally Posted by: Jean Giraud Originally Posted by: Joki720 Who has faced such a problem, how can it be solved? "result above max ..." has no pertinent meaning in your project. If you attempt "roots" on the numerator only ... "Units don't match" No need to go further ... zap the units in the project. I made a mistake, there should be a solve function, in this place the same error
Originally Posted by: Joki720 I made a mistake, there should be a solve function, in this place the same error Same answer: Units don't match. How can you solve what you can't plot or evaluate ?
You can use the function FindRoot() from the Nonlinear Solvers plugin. The function automatically assigns the solution to the variables. Единицы измерения здесь не при чем. |
Originally Posted by: mkraska You can use the function FindRoot() from the Nonlinear Solvers plugin. The function automatically assigns the solution to the variables. Единицы измерения здесь не при чем. why do you use 0.2 and 0.5?
Joki, Martin could have drawn the two curves and graphically estimated the two solutions
Originally Posted by: PompelmoTell Martin could have drawn the two curves and graphically estimated the two solutions
sergio The solution must be automatic, plotting make and evaluating it is not appropriate
Originally Posted by: Joki720 The solution must be automatic, plotting make and evaluating it is not appropriate OK ... don't plot => find min/max. Don't you need a road to drive the car from point A to point B ?
Originally Posted by: Joki720 Originally Posted by: PompelmoTell Martin could have drawn the two curves and graphically estimated the two solutions
sergio The solution must be automatic, plotting make and evaluating it is not appropriate Go on dreaming. If you are in non-linear systems and you can't find a symbolic solution (Maxima's Solve() got stuck when I tried) then you need numerical procedures for solution. These always need an initial guess (Newton-Raphson) or a search region (bisection). The various procedures just differ in how efficient or how robust they are. Some of them may have quite impressive radii of convergence for particular systems but none has infinite radius for all systems. Furthermore, there remains the problem of uniqueness of a solution. The only solvers in SMath capable of providing multiple solutions are the - solve() finds all solutions of a single equation within a given range
- Solve() from the Maxima plugin, which finds symbolic solutions.
Blatt21.sm (6kb) downloaded 15 time(s). |
Originally Posted by: mkraska Furthermore, there remains the problem of uniqueness of a solution. The only solvers in SMath capable of providing multiple solutions are the solve() finds all solutions of a single equation within a given range Solve() from the Maxima plugin, which finds symbolic solutions. Quite right and not enough wrt complex roots. Cubic solver Exercise.sm (39kb) downloaded 18 time(s).
Always avoid ill posed polynomials.
Joined: 08/02/2020(UTC) Posts: 3 Location: Roodepoort
To OP's original question. I did get the same/similar error message on linear interpolation. One of the 5 required values had wrong value. After correcting no issues.
Originally Posted by: Jouko To OP's original question. I did get the same/similar error message on linear interpolation. One of the 5 required values had wrong value. After correcting no issues. . What linear interpolation is doing here ? If that document makes sense, return with comments. Poverochnyjj raschjot ehzhektora [solve].sm (96kb) downloaded 9 time(s).
Originally Posted by: Jean Giraud What linear interpolation is doing here ? If that document makes sense, return with comments. I imagine you mean the very last part of the document. The system looks ill posed, visit Solve Lecture last 3 days. Poverochnyjj raschjot ehzhektora [solve, spline].sm (105kb) downloaded 14 time(s).
SMath Studio Forum
Questions
