Offline Joki720
#1 Posted : 12 February 2020 16:38:12(UTC)
Joki720
Rank: Member
Who has faced such a problem, how can it be solved?
Project from below
Poverochnyjj raschjot ehzhektora.sm (85kb) downloaded 15 time(s).
#2 Posted : 12 February 2020 18:07:47(UTC)
"result above max ..." has no pertinent meaning in your project.
If you attempt "roots" on the numerator only ... "Units don't match"
No need to go further ... zap the units in the project.
Offline Joki720
#3 Posted : 12 February 2020 18:38:24(UTC)
Joki720
Rank: Member
I made a mistake, there should be a solve function, in this place the same error
#4 Posted : 12 February 2020 20:57:49(UTC)
Same answer: Units don't match.
How can you solve what you can't plot or evaluate ?
#5 Posted : 13 February 2020 13:44:15(UTC)
You can use the function FindRoot() from the Nonlinear Solvers plugin. The function automatically assigns the solution to the variables.
Единицы измерения здесь не при чем.
2020-02-13 11_38_00-SMath Studio 0.99.7251 - [Poverochnyjj%20raschjot%20ehzhektora.sm_].png
on 14/02/2020(UTC)
Offline Joki720
#6 Posted : 14 February 2020 19:09:51(UTC)
Joki720
Rank: Member
why do you use 0.2 and 0.5?
Offline PompelmoTell
#7 Posted : 14 February 2020 19:57:29(UTC)
PompelmoTell
Joki,
Martin could have drawn the two curves and graphically estimated the two solutions
Offline Joki720
#8 Posted : 14 February 2020 20:52:49(UTC)
Joki720
Rank: Member
The solution must be automatic, plotting make and evaluating it is not appropriate
#9 Posted : 15 February 2020 01:34:05(UTC)
OK ... don't plot => find min/max.
Don't you need a road to drive the car from point A to point B ?
#10 Posted : 15 February 2020 04:56:17(UTC)
Common from ill posed construction.
Consider yellow up until you can plot that system(x,y):= ....
from there it should be solvable.
Poverochnyjj raschjot ehzhektora [zap Units, define the Undefined ...].sm (95kb) downloaded 16 time(s).
#11 Posted : 15 February 2020 12:37:16(UTC)
Go on dreaming. If you are in non-linear systems and you can't find a symbolic solution (Maxima's Solve() got stuck when I tried) then you need numerical procedures for solution. These always need an initial guess (Newton-Raphson) or a search region (bisection). The various procedures just differ in how efficient or how robust they are. Some of them may have quite impressive radii of convergence for particular systems but none has infinite radius for all systems.
Furthermore, there remains the problem of uniqueness of a solution. The only solvers in SMath capable of providing multiple solutions are the
  • solve() finds all solutions of a single equation within a given range
  • Solve() from the Maxima plugin, which finds symbolic solutions.
Blatt21.sm (6kb) downloaded 15 time(s).
#12 Posted : 15 February 2020 18:10:50(UTC)
Quite right and not enough wrt complex roots.
Cubic solver Exercise.sm (39kb) downloaded 18 time(s).
#13 Posted : 15 February 2020 23:54:43(UTC)
Always avoid ill posed polynomials.
Offline Jouko
#14 Posted : 16 February 2020 21:10:14(UTC)
Jouko
South Africa
To OP's original question. I did get the same/similar error message on linear interpolation. One of the 5 required values had wrong value. After correcting no issues.
#15 Posted : 17 February 2020 02:47:13(UTC)
What linear interpolation is doing here ?
If that document makes sense, return with comments.
Poverochnyjj raschjot ehzhektora [solve].sm (96kb) downloaded 9 time(s).
#16 Posted : 17 February 2020 05:09:30(UTC)
I imagine you mean the very last part of the document.
The system looks ill posed, visit Solve Lecture last 3 days.
Poverochnyjj raschjot ehzhektora [solve, spline].sm (105kb) downloaded 14 time(s).
#17 Posted : 17 February 2020 15:35:01(UTC)
... maybe we can leave it as such ... cleanup ?
Poverochnyjj raschjot ehzhektora [solve, spline].sm (111kb) downloaded 15 time(s).
Inst_Isentropic Discharge.sm (174kb) downloaded 20 time(s).
Guest (2)
