SMath Studio Forum
Questions
Create tab demlimited data file (notepad) using Smath
Hi I wanted to know if it is possible to create tab delimited data file (.txt) using Smath. Txt Data file should contain different columns of a computed matrix in Smath
try "Data exchange" plugin
More generally from long times ago, universal data exchange is *.dat
Originally Posted by: jaivishnu I wanted to know if it is possible to create tab delimited data file (.txt) using Smath. Txt Data file should contain different columns of a computed matrix in Smath 1. Copy the matrix data 2. Paste in NotePad
3. Select all in NotePad, copy 3. Paste back in Smath New:= pasteWhat is Tab Delimited data ?
mat(1,2,3,2,4,6,3,6,9,3,3)
copy, paste in Smath assigned argument [mymatrix] mymatrix:=
Under the hood, spooling to file is mat(1,2,3,2,4,6,3,6,9,3,3)
You can use ExportData.CSV() from the DataExchange plugin. It doesn't generate tab-delimited files. If really needed, you can replace the commas by tabs using some script or filter command. exportData.CSV.sm (24kb) downloaded 17 time(s). |
SMath Studio Forum
Questions
