Offline jaivishnu
#1 Posted : 22 February 2020 16:23:14(UTC)
jaivishnu
India
Hi
I wanted to know if it is possible to create tab delimited data file (.txt) using Smath. Txt Data file should contain different columns of a computed matrix in Smath
Offline PompelmoTell
#2 Posted : 22 February 2020 18:15:25(UTC)
PompelmoTell
try "Data exchange" plugin
#3 Posted : 23 February 2020 17:55:44(UTC)
More generally from long times ago, universal data exchange is *.dat
#4 Posted : 25 February 2020 03:02:38(UTC)
1. Copy the matrix data
2. Paste in NotePad
3. Select all in NotePad, copy
3. Paste back in Smath New:= paste
What is Tab Delimited data ?
#5 Posted : 25 February 2020 16:26:17(UTC)
mat(1,2,3,2,4,6,3,6,9,3,3)
copy, paste in Smath assigned argument [mymatrix]
mymatrix:=
Under the hood, spooling to file is
#6 Posted : 25 February 2020 18:12:45(UTC)
You can use ExportData.CSV() from the DataExchange plugin. It doesn't generate tab-delimited files. If really needed, you can replace the commas by tabs using some script or filter command.
exportData.CSV.sm (24kb) downloaded 17 time(s).
