SMath Studio Forum
Questions
How can I put CRLF character directly into string?
Hi, everyone! Now I doing it like this: Is there another way to put break line into string? Edited by user 25 February 2020 22:59:50(UTC)
| Reason: Clarification
Sorry AllexII: don't understand what you are trying to do in Smath ? You can probably split by additional condition.
AFIU ... [As Far I Understand] You can insert descriptive text in conditional. Page37 AFIU.sm (8kb) downloaded 17 time(s).
I want to see result in 2 or more string. Is there any symbol of break line? "1st string 2nd string"
The question is not very clear; if it is only a practical problem where the use of "stack" creates a very long line that comes out of the sheet, then simply use the structure of the matrix directly and insert the vector with as many lines as you want. sergio
The question is, can a string consist of two or more lines, if so - what does the line wrap symbol look like?
Originally Posted by: AlexIl The question is, can a string consist of two or more lines, if so - what does the line wrap symbol look like? Like this in the attached SS 6179 Page37 AFIU.sm (19kb) downloaded 12 time(s).
put the cursor on right of "Not yet in orbit Kamarad !" press coma to add one line place holder to fill-in coma coma coma for 3 more
put the cursor on left of "Not yet in orbit Kamarad !" press coma to add one line place holder to fill-in coma coma coma for 3 more
Was thanked: 21 time(s) in 17 post(s)
I do it this way: To create the linefeed, I modified the smath sheet with an text editor I think (Don't remember exactly.) Code:
<input>
<e type="operand">\0040\CRLF</e>
<e type="operand" style="string">
</e>
<e type="operator" args="2">:</e>
</input>
Edited by user 25 February 2020 10:46:39(UTC)
| Reason: new screenshot
1 user thanked MarB for this useful post.
MarB, thank you! This is exactly what I want. Really has no one ever had this problem before?
Originally Posted by: AlexIl This is exactly what I want. Really has no one ever had this problem before? Many Smath users, like myself, stick to native Smath. Much easier to exchange documents, sanity Quality Control. You may have to check spooling to file ?
Originally Posted by: Jean Giraud Many Smath users, like myself, stick to native Smath. Much easier to exchange documents, sanity Quality Control. You may have to check spooling to file ?
Maybe, I don't understand what you are looking for. It works native Smath for my own end needs. The coding of spool to file should create the file in your system. Page37 AFIU spooled2file.sm (22kb) downloaded 20 time(s).
I would like to be able to enter the CRLF character directly when entering a string without functions "stack", "concat" or "sys". For example, when you press Ctrl + Shift + Enter. Page37 AFIU spooled2file.sm (21kb) downloaded 19 time(s).Edited by user 25 February 2020 22:55:28(UTC)
Originally Posted by: AlexIl I would like to be able to enter the CRLF character directly when entering a string without functions "stack", "concat" or "sys". For example, when you press Ctrl Shift Enter. Sorry Kamarad, I found no way to do. Hope Martin will catch and doctor.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,652 Location: Italy Was thanked: 1339 time(s) in 878 post(s)
Originally Posted by: Jean Giraud I would like to be able to enter the CRLF character directly when entering a string without functions "stack", "concat" or "sys". For example, when you press Ctrl Shift Enter. Your coding works only on your transmitted document, i.e: does not work on a blank sheet SS 6179. As it looks, there is no key stroke to make same as ,\0040\CRLF, To insert the music symbol: 1. from Charmap Arial, select twice, highlight, copy 2. paste in free space, type 1 for instance for enabling the paste. Then backspace 1 to remove. Same thing, type 2 if you prefer.
Originally Posted by: Jean Giraud ... more from Martin, long time ago. Bigger size for GrandMa !!!
SMath Studio Forum
Questions
