Offline AlexIl
#1 Posted : 24 February 2020 17:16:26(UTC)
AlexIl
Hi, everyone!
Now I doing it like this:
Is there another way to put break line into string?
Edited by user 25 February 2020 22:59:50(UTC)  | Reason: Clarification
#2 Posted : 24 February 2020 18:38:57(UTC)
Sorry AllexII: don't understand what you are trying to do in Smath ?
You can probably split by additional condition.
#3 Posted : 24 February 2020 19:37:40(UTC)
AFIU ... [As Far I Understand]
You can insert descriptive text in conditional.
Page37 AFIU.sm (8kb) downloaded 17 time(s).
Offline AlexIl
#4 Posted : 24 February 2020 19:38:13(UTC)
AlexIl
I want to see result in 2 or more string. Is there any symbol of break line?
"1st string
2nd string"
Offline PompelmoTell
#5 Posted : 24 February 2020 21:30:35(UTC)
PompelmoTell
The question is not very clear; if it is only a practical problem where the use of "stack" creates a very long line that comes out of the sheet, then simply use the structure of the matrix directly and insert the vector with as many lines as you want.
Offline AlexIl
#6 Posted : 24 February 2020 21:47:02(UTC)
AlexIl
The question is, can a string consist of two or more lines, if so - what does the line wrap symbol look like?
#7 Posted : 24 February 2020 23:06:39(UTC)
Like this in the attached SS 6179
Page37 AFIU.sm (19kb) downloaded 12 time(s).
#8 Posted : 24 February 2020 23:20:07(UTC)
put the cursor on right of "Not yet in orbit Kamarad !"
press coma to add one line place holder to fill-in
coma coma coma for 3 more
put the cursor on left of "Not yet in orbit Kamarad !"
Offline MarB
#9 Posted : 25 February 2020 10:36:52(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
I do it this way:
To create the linefeed, I modified the smath sheet with an text editor I think (Don't remember exactly.)
Code:
        <input>
          <e type="operand">\0040\CRLF</e>
          <e type="operand" style="string">
</e>
          <e type="operator" args="2">:</e>
        </input>
Edited by user 25 February 2020 10:46:39(UTC)  | Reason: new screenshot
thanks 1 user thanked MarB for this useful post.
on 25/02/2020(UTC)
Offline AlexIl
#10 Posted : 25 February 2020 12:11:24(UTC)
AlexIl
MarB, thank you! This is exactly what I want. Really has no one ever had this problem before?
#11 Posted : 25 February 2020 16:09:15(UTC)
Many Smath users, like myself, stick to native Smath.
Much easier to exchange documents, sanity Quality Control.
You may have to check spooling to file ?
#12 Posted : 25 February 2020 16:59:03(UTC)
Maybe, I don't understand what you are looking for.
It works native Smath for my own end needs.
The coding of spool to file should create the file in your system.
Page37 AFIU spooled2file.sm (22kb) downloaded 20 time(s).
Offline AlexIl
#13 Posted : 25 February 2020 22:53:02(UTC)
AlexIl
I would like to be able to enter the CRLF character directly when entering a string without functions "stack", "concat" or "sys". For example, when you press Ctrl + Shift + Enter.
Page37 AFIU spooled2file.sm (21kb) downloaded 19 time(s).
Edited by user 25 February 2020 22:55:28(UTC)  | Reason: Not specified
#14 Posted : 26 February 2020 06:21:56(UTC)
I would like to be able to enter the CRLF character directly when entering a string without functions "stack", "concat" or "sys". For example, when you press Ctrl Shift Enter.
Sorry Kamarad, I found no way to do.
Hope Martin will catch and doctor.
#15 Posted : 26 February 2020 15:35:30(UTC)
Was thanked: 1339 time(s) in 878 post(s)
appendLines.sm (5kb) downloaded 42 time(s).
on 26/02/2020(UTC)
#16 Posted : 26 February 2020 17:58:40(UTC)
Your coding works only on your transmitted document,
i.e: does not work on a blank sheet SS 6179.
As it looks, there is no key stroke to make same as ,\0040\CRLF,
To insert the music symbol:
1. from Charmap Arial, select twice, highlight, copy
2. paste in free space, type 1 for instance
for enabling the paste. Then backspace 1 to remove.
Same thing, type 2 if you prefer.
#17 Posted : 27 February 2020 16:27:20(UTC)
... more from Martin, long time ago.
2D Util Bar Fourier_Martin.sm (81kb) downloaded 21 time(s).
#18 Posted : 27 February 2020 16:50:19(UTC)
Bigger size for GrandMa !!!
on 27/02/2020(UTC)
