Offline eltonsfg
#1 Posted : 18 April 2020 13:24:19(UTC)
eltonsfg
I can't solve the equation below, I tried two options but none worked. Someone could help?
Elton Freitas
#2 Posted : 18 April 2020 13:42:44(UTC)
Originally Posted by: eltonsfg Go to Quoted Post
I can't solve the equation below, I tried two options but none worked. Someone could help ?
Please: attach the document for the missing data.
Offline PompelmoTell
#3 Posted : 18 April 2020 17:20:12(UTC)
PompelmoTell
Let's start by observing that:
1) the "solve" function is native to smath but does not accept units of measurement (if you want to use it you must temporarily get rid of the units of measurement)
2) the "FindRoot" function you have defined relies on "solve" (see above)
3) in the "nonlinear Solver" plugin you will find a "FindRoot" function that can do for you and that manages the units of measurement
4) there are other features and plugins that can help you. I suggest you also consult Martin Kraska's Interactive SMath Handbook with lots of information and practical examples (you can find it in the tool you use to install plugins)
Offline eltonsfg
#4 Posted : 18 April 2020 19:23:01(UTC)
eltonsfg
Yes. It is attached or attached. Modelo_Planilha de Calculos_OM_rev02.sm (2,262kb) downloaded 15 time(s).
Thank you.
Best Regard.
Elton Freitas
Offline hawe
#5 Posted : 18 April 2020 20:11:13(UTC)
hawe
Was thanked: 3 time(s) in 2 post(s)
a quadratic equation, solved algebraically?
MPa^2=((σ.solda)/(a.cordao))^(2)+3*((P.total)/(2*h*a.cordao))^(2)
sys(a.cordao≡-sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},a.cordao≡sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},2,1)
