Joined: 06/03/2020(UTC) Posts: 3 Location: Paço de arcos
I can't solve the equation below, I tried two options but none worked. Someone could help? Best regards Elton Freitas
Originally Posted by: eltonsfg I can't solve the equation below, I tried two options but none worked. Someone could help ?
Please: attach the document for the missing data. Jean
Joined: 23/12/2011(UTC) Posts: 320 Location: italy Was thanked: 109 time(s) in 93 post(s)
Let's start by observing that: 1) the "solve" function is native to smath but does not accept units of measurement (if you want to use it you must temporarily get rid of the units of measurement) 2) the "FindRoot" function you have defined relies on "solve" (see above) 3) in the "nonlinear Solver" plugin you will find a "FindRoot" function that can do for you and that manages the units of measurement 4) there are other features and plugins that can help you. I suggest you also consult Martin Kraska's Interactive SMath Handbook with lots of information and practical examples (you can find it in the tool you use to install plugins)
Joined: 30/03/2020(UTC) Posts: 31 Location: KU Was thanked: 3 time(s) in 2 post(s)
a quadratic equation, solved algebraically?
MPa^2=((σ.solda)/(a.cordao))^(2)+3*((P.total)/(2*h*a.cordao))^(2)
sys(a.cordao≡-sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},a.cordao≡sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},2,1)
