They talk about us
As a student engineer, this is an amazing program to use for future engineers.
more...
by Erich Vajda
Mi programa favorito para calculos matematicos en general
more...
by Joan Enric Coca
This fantastic free alternative to Mathcad is going from strength to strength and I am really enjoying watching its progress. Andrey has produced something that is genuinely useful, multiplatform, fun to use and, most importantly of all, he listens to his users. Well worth a download.
more...
by Mike Croucher
on 27/12/2020(UTC), on 27/12/2020(UTC), on 27/12/2020(UTC), on 28/12/2020(UTC), on 28/12/2020(UTC), on 01/01/2021(UTC)
Impressive progress, Andrey.
I think the math detection is a bit over-greedy. As soon as I type a hyphen, the preceeding word is taken as a variable name and a math region is embedded. Thus the only way to add a hyphen between two words is to embrace it with spaces and delete the spaces afterwards. I'd recommend to do the conversion when Enter is pressed. A second enter then would leave the embedded math region. |
3 users thanked mkraska for this useful post.
on 28/12/2020(UTC), on 28/12/2020(UTC), on 29/12/2020(UTC)
Thank you Martin very much for this suggestion!
I'm thinking about ways to make this detection more smart, more predictable to user and be easily cancelable (meaning it should be possible to cancel/undo it when it is done incorrectly or user wants to leave text as is). I have some thoughts about it, so yeah, this will be significantly improved.
Regards.
Joined: 28/08/2014(UTC) Posts: 1,371 Was thanked: 834 time(s) in 528 post(s)
Hi. Thanks for the new features. BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description. paste.sm (4kb) downloaded 12 time(s).Best regards. Alvaro.
Originally Posted by: Razonar BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description. Hello Alvaro. Thank you! Will fix it asap.
I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error. Thanks, Jason |
1 user thanked Jason McCool for this useful post.
Thank you! Originally Posted by: Jason McCool I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error. The reason of this error is the same as it is in the issue
Razonar
mentioned above. Fixed now. Best regards.
