They talk about us
Es excelente, me resulta más eficiente si la comparamos con las herramientas que se le parecen
more...
by Carlos Daniel Encarnación Zúñiga
I have used MathCAD since 1997. Loved it. I used to work for the Nuclear Industry in Canada, and we had these long calculation sheets fully written in MathCAD. As an independent researcher, I also had a student version which I could simply purchase from a campus bookstore as a CD. A few years later, disaster struck! A greedy corporate entity purchased MathCAD and destroyed it. A tool created for engineers by engineers with engineering in mind was destroyed by MBAs with only money in their minds. I was helpless until I discovered SMath. I was amazed at how SMath could do so many things with the installation file being just a few MB! And Andrey simply gave it away to us for free!! SMath has truly filled the void left by the now-extinct "old MathCAD". The fact that SMath is not bloatware and gives us researchers exactly what we need are reasons enough to call Andrey a genius. My dear Andrey, many of us are out there in various parts of the world quietly blessing you for helping us do our research calculations. You are a noble soul with a spirit that cares for a better world. Trust me, you have in your own way made our world a better place to live through SMath. God bless you. I shall surely donate an amount as a symbolic gesture for your great work. Please continue to serve the world and may God bless you with good health, a long life, peace, prosperity, and a sound mind that scientifically contributes for as long as you live and pave the way for your glorious legacy long after we are all gone.
more...
by Dr. M Sathya Prasad
Es un imprescindible para el día a día. Muchísimas gracias Mr Andrey Ivashov.
more...
by Ángel Álvarez
on 27/12/2020(UTC), on 27/12/2020(UTC), on 27/12/2020(UTC), on 28/12/2020(UTC), on 28/12/2020(UTC), on 01/01/2021(UTC)
Impressive progress, Andrey.
I think the math detection is a bit over-greedy. As soon as I type a hyphen, the preceeding word is taken as a variable name and a math region is embedded. Thus the only way to add a hyphen between two words is to embrace it with spaces and delete the spaces afterwards. I'd recommend to do the conversion when Enter is pressed. A second enter then would leave the embedded math region. |
3 users thanked mkraska for this useful post.
on 28/12/2020(UTC), on 28/12/2020(UTC), on 29/12/2020(UTC)
Thank you Martin very much for this suggestion!
I'm thinking about ways to make this detection more smart, more predictable to user and be easily cancelable (meaning it should be possible to cancel/undo it when it is done incorrectly or user wants to leave text as is). I have some thoughts about it, so yeah, this will be significantly improved.
Regards.
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 827 time(s) in 524 post(s)
Hi. Thanks for the new features. BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description. paste.sm (4kb) downloaded 12 time(s).Best regards. Alvaro.
Originally Posted by: Razonar BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description. Hello Alvaro. Thank you! Will fix it asap.
I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error. Thanks, Jason |
1 user thanked Jason McCool for this useful post.
Thank you! Originally Posted by: Jason McCool I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error. The reason of this error is the same as it is in the issue
Razonar
mentioned above. Fixed now. Best regards.
