SMath Studio Forum
Questions
Symbolic resolution from mathcad to SMath-Studio
Joined: 13/11/2020(UTC) Posts: 28 Was thanked: 7 time(s) in 3 post(s)
How can I do a symbolic resolution in SMath-Studio? In mathcad there are: simplify, expand, substitute, etc. When I solve an equation, I have to use "maple". Can this be done without using it? Mathcad to SMath Studio.sm (104kb) downloaded 24 time(s).
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
The built in symbolic engine in SMath leaves much to be desired. I know the maple plugin has at least some of the functionality you're looking for. Also you'll want to check out the Maxima plugin as that's very useful for solving symbolic equations as well. |
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Originally Posted by: Valentino How can I do a symbolic resolution in SMath-Studio? In Mathcad there are: simplify, expand, substitute, etc. Most Mathcad command line work as well in Smath. ODE Maple Example Copy.sm (119kb) downloaded 44 time(s).
Originally Posted by: Jean Giraud Most Mathcad command line work as well in Smath. ... augmented version. ODE Maple Example Copy.sm (135kb) downloaded 32 time(s).
Maple and Maxima plugins has symbolic simplify functions. Unfortunately SMath don't have this features natively.
Originally Posted by: Valentino How can I do a symbolic resolution in SMath-Studio? In Mathcad there are: simplify, expand, substitute, etc. Which of these 6 styles do you prefer ? Mathematica has a long discours on that .
You can write your own functions to make expand(),simplify() work as if they are implemented. Don't sure if they will work with complicated function, but they are fine with simple ones. Regards
Originally Posted by: Razonar Alvaro thank you very much, your solution has worked very well for me. I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement?
Originally Posted by: Jean Giraud Originally Posted by: Valentino How can I do a symbolic resolution in SMath-Studio? In Mathcad there are: simplify, expand, substitute, etc. Most Mathcad command line work as well in Smath. ODE Maple Example Copy.sm (119kb) downloaded 44 time(s). Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Conver" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for?
Originally Posted by: Jean Giraud Originally Posted by: Valentino How can I do a symbolic resolution in SMath-Studio? In Mathcad there are: simplify, expand, substitute, etc. Which of these 6 styles do you prefer ? Mathematica has a long discours on that . How did you put so many "boolean equals" without the parentheses being uncertain? ¿Cómo pusiste tantos "iguales booleanos" sin que los paréntesis sean inciertos? Thank you
Originally Posted by: Valentino How did you put so many "boolean equals" without the parentheses From an old Mathcad/Mathsoft contest.
Originally Posted by: Valentino Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Convert" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for ? They just make the demand produce/solve. Few more attached as you may need eventually. Cheers Valentino ... Jean Symbolic Convert Parfrac Primary FNCTS.sm (119kb) downloaded 29 time(s).
Originally Posted by: Valentino ...I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; ... Opt = Symbolic or Opt = None means that you must to right click over an expression, and choose Optimization / Symbolic or None, not a command. About collect and other expression they aren't from SMath, but from Maple plugin, which is Maple version 6. So, you must to learn something about it. Maplesoft online help could be very extended: Maple help but you can also read some good manuals like "Aprenda Maple 8 como si estuviera en primero" from Universidad de Navarra (you can google it, it's free). Just a notice: Maple V have several differences about how handle strings and some other things, so if you can't find a good short manual about Maple 6 try only up versions. Best regards. Alvaro.
Originally Posted by: Jean Giraud Few more attached as you may need eventually The continued fractions are not futile ... Explain. Before the modern CAS, the main frame IBM, used continued fractions. As well as the J_Fraction... Where is my Mathcad on that ? Since then, the Padé normalized fractions have replaced the continued fractions, more stable numerically, faster parallel. Jean
... Expand options
... matter of preference. Expand.sm (14kb) downloaded 19 time(s).
Originally Posted by: Razonar With some hard work you can hack the SMath syntax. Best regards. Alvaro. This is nice. I didn't know it could be done. Formulas work even after brackets removed. Not just a cosmetic removal. Thanks a lot.
SMath Studio Forum
Questions
