Offline Valentino
#1 Posted : 31 August 2021 22:23:02(UTC)
Valentino
Rank: Member
Mexico
Was thanked: 7 time(s) in 3 post(s)
How can I do a symbolic resolution in SMath-Studio?
In mathcad there are: simplify, expand, substitute, etc.
When I solve an equation, I have to use "maple". Can this be done without using it?
Mathcad to SMath Studio.sm (104kb) downloaded 25 time(s).
Offline alyles
#2 Posted : 31 August 2021 22:52:14(UTC)
alyles
United States
The built in symbolic engine in SMath leaves much to be desired.
I know the maple plugin has at least some of the functionality you're looking for. Also you'll want to check out the Maxima plugin as that's very useful for solving symbolic equations as well.
Offline Razonar
#3 Posted : 01 September 2021 01:34:42(UTC)
Razonar
Uruguay
Was thanked: 833 time(s) in 527 post(s)
Hi Valentino. This is a way.
Mathcad to SMath Studio.sm (103kb) downloaded 95 time(s).
on 01/09/2021(UTC)
#4 Posted : 01 September 2021 02:00:34(UTC)
In Mathcad there are: simplify, expand, substitute, etc.
Most Mathcad command line work as well in Smath.
ODE Maple Example Copy.sm (119kb) downloaded 44 time(s).
on 01/09/2021(UTC)
#5 Posted : 01 September 2021 15:16:33(UTC)
... augmented version.
ODE Maple Example Copy.sm (135kb) downloaded 32 time(s).
Offline overlord
#6 Posted : 01 September 2021 22:40:43(UTC)
Turkey
Maple and Maxima plugins has symbolic simplify functions.
Unfortunately SMath don't have this features natively.
#7 Posted : 02 September 2021 00:36:42(UTC)
Which of these 6 styles do you prefer ?
Mathematica has a long discours on that .
Offline overlord
#8 Posted : 02 September 2021 01:01:18(UTC)
Turkey
You can write your own functions to make expand(),simplify() work as if they are implemented.
Don't sure if they will work with complicated function, but they are fine with simple ones.
Offline Valentino
#9 Posted : 02 September 2021 02:05:05(UTC)
Valentino
Rank: Member
Mexico
Alvaro thank you very much, your solution has worked very well for me. I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement?
Offline Valentino
#10 Posted : 02 September 2021 02:09:47(UTC)
Valentino
Rank: Member
Mexico
Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Conver" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for?
Offline Valentino
#11 Posted : 02 September 2021 02:18:08(UTC)
Valentino
Rank: Member
Mexico
How did you put so many "boolean equals" without the parentheses being uncertain?
¿Cómo pusiste tantos "iguales booleanos" sin que los paréntesis sean inciertos?
Thank you
#12 Posted : 02 September 2021 02:59:49(UTC)
From an old Mathcad/Mathsoft contest.
#13 Posted : 02 September 2021 03:05:48(UTC)
Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Convert" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for ?
They just make the demand produce/solve.
Few more attached as you may need eventually.
Cheers Valentino ... Jean
Symbolic Convert Parfrac Primary FNCTS.sm (119kb) downloaded 30 time(s).
Offline Razonar
#14 Posted : 02 September 2021 03:36:51(UTC)
Razonar
Uruguay
...I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; ...
Opt = Symbolic or Opt = None means that you must to right click over an expression, and choose Optimization / Symbolic or None, not a command.
About collect and other expression they aren't from SMath, but from Maple plugin, which is Maple version 6. So, you must to learn something about it. Maplesoft online help could be very extended: Maple help but you can also read some good manuals like "Aprenda Maple 8 como si estuviera en primero" from Universidad de Navarra (you can google it, it's free). Just a notice: Maple V have several differences about how handle strings and some other things, so if you can't find a good short manual about Maple 6 try only up versions.
Offline Razonar
#15 Posted : 02 September 2021 03:45:04(UTC)
Razonar
Uruguay
With some hard work you can hack the SMath syntax: From https://en.smath.com/for...-requests.aspx#post56111
HackingEqual.sm (4kb) downloaded 56 time(s).
on 02/09/2021(UTC)
#16 Posted : 02 September 2021 03:48:40(UTC)
The continued fractions are not futile ... Explain.
Before the modern CAS, the main frame IBM, used continued fractions.
As well as the J_Fraction... Where is my Mathcad on that ?
Since then, the Padé normalized fractions have replaced
the continued fractions, more stable numerically, faster parallel.
#17 Posted : 02 September 2021 04:12:27(UTC)
... Expand options
#18 Posted : 02 September 2021 04:21:44(UTC)
... matter of preference.
Expand.sm (14kb) downloaded 19 time(s).
#19 Posted : 02 September 2021 15:03:30(UTC)
... more for your bed time reading, Valentino !
Smath is not envious of PTC_Mathcad ... Jean.
Inst_TurboGen Smath [SHORT].sm (20kb) downloaded 16 time(s).
Inst_TurboGen Signum.sm (87kb) downloaded 12 time(s).
Inst_TurboGen Smath.sm (119kb) downloaded 20 time(s).
Offline overlord
#20 Posted : 02 September 2021 17:24:40(UTC)
Turkey
With some hard work you can hack the SMath syntax.
This is nice. I didn't know it could be done.
Formulas work even after brackets removed.
Not just a cosmetic removal.
Thanks a lot.
