9 Pages«<6789>
#141 Posted : 02 April 2023 13:55:06(UTC)
Thank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching.
Offline uni
#142 Posted : 02 April 2023 14:02:21(UTC)
uni
This is not the book itself, but the calculations that are used there. Unfortunately, the level of knowledge of the program leaves much to be desired. I made comments to the authors.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Razonar
#143 Posted : 02 April 2023 15:31:14(UTC)
Razonar
Uruguay
Was thanked: 819 time(s) in 518 post(s)
Hi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane.
3body.sm (38kb) downloaded 5 time(s).
on 02/04/2023(UTC)
Offline uni
#144 Posted : 02 April 2023 15:34:42(UTC)
uni
It is necessary to choose the conditions of the problem in such a way that the massive body intercepts the satellite.
Russia ☭ forever
on 02/04/2023(UTC)
#145 Posted : 02 April 2023 15:36:00(UTC)
So we can look forward for an inproved version. Could you please share your comments, eventually in PM...
The pdf can be found here. I downloaded all the stuff from the companion site, who knows how long we can access this.
Unfortunately, copying from the pdf to chatgpt for translation doesn't work Sad
Offline uni
#146 Posted : 02 April 2023 15:39:27(UTC)
uni
You can find one of the authors here. He is open to suggestions and comments.
Links:
1. Mathcad vs SMath
Edited by user 02 April 2023 15:41:07(UTC)  | Reason: Not specified
Russia ☭ forever
Offline Razonar
#147 Posted : 02 April 2023 16:20:06(UTC)
Razonar
Uruguay
Hi. Ok.
3body.sm (38kb) downloaded 14 time(s).
thanks 2 users thanked Razonar for this useful post.
on 02/04/2023(UTC),  on 03/04/2023(UTC)
Offline uni
#148 Posted : 03 April 2023 10:19:19(UTC)
uni
Hi. Ok.
A very witty, funny and clean solution. Clapping
Click to enlarge
7-13-Three-Planets 5 (Mathcad Block).sm (27kb) downloaded 24 time(s).
7-13-Three-Planets 5 (Mathcad Block).pdf (62kb) downloaded 19 time(s).
Edited by user 03 April 2023 10:40:46(UTC)  | Reason: Not specified
Russia ☭ forever
on 03/04/2023(UTC),  on 04/04/2023(UTC)
Offline uni
#149 Posted : 04 April 2023 07:59:18(UTC)
uni
Little bit more.
Click to enlarge
7-13-Three-Planets 6 (Mathcad Block).sm (27kb) downloaded 27 time(s).
7-13-Three-Planets 6 (Mathcad Block).pdf (68kb) downloaded 16 time(s).
Russia ☭ forever
on 04/04/2023(UTC)
Offline Razonar
#150 Posted : 05 April 2023 01:05:04(UTC)
Razonar
Uruguay
Utility for call dsolvers for initial and boundary values problems from a solver block.
RKA.pdf (932kb) downloaded 31 time(s).
RKA.sm (309kb) downloaded 23 time(s).
on 05/04/2023(UTC)
Offline CBG
#151 Posted : 05 April 2023 02:57:48(UTC)
CBG
Hello
I Can't Install the Mathcad Toolbox Plugin
Click to enlarge
Edited by moderator 05 April 2023 07:45:37(UTC)  | Reason: Not specified
Offline uni
#152 Posted : 05 April 2023 07:53:12(UTC)
uni
Does it happen only with this plugin or with others the same? Try deleting the plugins folder completely and try installing again.
Russia ☭ forever
Offline uni
#153 Posted : 05 April 2023 08:29:16(UTC)
uni
You can add your documents as add-ons and then include them with the include() function.
This function automatically searches for files in the folder with extensions. This way you can update them individually.
Edited by user 05 April 2023 08:32:43(UTC)  | Reason: Not specified
Russia ☭ forever
on 05/04/2023(UTC)
Offline uni
#154 Posted : 05 April 2023 10:28:42(UTC)
uni
'Given' keyword also can be supported but I don't know how it will look like. Only the component has the ability to receive a set of elements on a sheet. The solution should be convenient and universal.
Edited by user 05 April 2023 10:31:36(UTC)  | Reason: Not specified
Russia ☭ forever
Offline Razonar
#155 Posted : 05 April 2023 18:01:21(UTC)
Razonar
Uruguay
You can add your documents as add-ons and then include them with the include() function. ... This function automatically searches for files in the folder with extensions. This way you can update them individually.
Hi. That function looks great. Is there an example of using a document as an add-on?
Offline Razonar
#156 Posted : 06 April 2023 01:54:34(UTC)
Razonar
Uruguay
I think that SMath do not need a Given - Find block, because it have your solve block. For example, it could be used like this
Offline uni
#157 Posted : 06 April 2023 16:29:56(UTC)
uni
Try to log in here using the registration data in the program: https://en.smath.com/upload/extensions.aspx
You should see this picture:
Click to enlarge
Next, you need to choose the type of extension
Click to enlarge
Before uploading a file, you need to fill in the document properties. Later, you can delete the file if necessary.
Click to enlarge
If the registration data is not suitable, then you need to request them from Andrey via e-mail.
The registered files will be available through the gallery.
Click to enlarge
Edited by user 06 April 2023 16:36:11(UTC)  | Reason: Not specified
Russia ☭ forever
on 06/04/2023(UTC),  on 07/04/2023(UTC)
Offline uni
#158 Posted : 17 April 2023 12:58:15(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- added support for sequence operation (sys - default, mat, line);
- base frames drawing for error and eval states restored.
Click to enlarge Click to enlarge
Edited by user 17 April 2023 13:24:34(UTC)  | Reason: Not specified
Russia ☭ forever
on 17/04/2023(UTC),  on 17/04/2023(UTC),  on 17/04/2023(UTC)
#159 Posted : 17 April 2023 22:43:23(UTC)
Unfortunately, I can't reproduce your parametric plot example.
It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this?
BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension?
Mathcad block.sm (14kb) downloaded 11 time(s).
Offline Razonar
#160 Posted : 17 April 2023 23:22:41(UTC)
Razonar
Uruguay
...How to fix this? ...
Use ~t instead t in list, but t in the range.
That's very original!
9 Pages«<6789>
