Offline OchkovVF
#1 Posted : 04 May 2023 08:46:08(UTC)
OchkovVF
Was thanked: 50 time(s) in 43 post(s)
Edited by moderator 04 May 2023 15:48:29(UTC)  | Reason: Not specified
#2 Posted : 04 May 2023 14:50:28(UTC)
Was thanked: 983 time(s) in 811 post(s)
I don't vote for ... Pressure would be 2 pages wide !
Of no use for Engineering works.
on 04/05/2023(UTC)
Offline overlord
#3 Posted : 04 May 2023 15:01:36(UTC)
Turkey
Was thanked: 548 time(s) in 368 post(s)
I would definitely support this.
But it will require essential code change.
And it wouldn't be easy I suppose.
Wouldn't expect it to be implemented.
Mean while, you can use text region for that purpose.
Won't be easy to write, won't look as good as math region.
But it will serve you what you seek.
chained equalities.sm (9kb) downloaded 5 time(s).
on 04/05/2023(UTC)
Offline Kenny Lemens
#4 Posted : 04 May 2023 16:55:45(UTC)
Kenny Lemens
United States
Was thanked: 73 time(s) in 46 post(s)
Greetings,
I would be against this feature as well. As Overlord indicated, support already exists to produce an effect similar to that requested.
On the other hand, as a programmer; I would have no idea how you could easily implement this:
  • Even if you limit it to just temperature units, change in temperature is still a temperature unit (i.e., 'Δ°C; 'Δ°F; 'Δ°Re) (e.g., ... = 112.55°F⛅ = 572.22°FΔ = ...)
  • Would have to be limited to base units only (as you could have a infinite combinations of units to result in the 'unit' (e.g., need to include {'Δ°C*'Δ°Re}/'Δ°F as a temperature unit ...)
  • Decimal places: not all units are the same! Units of length: inch vs. miles, mm vs lightyears; need to compare really small units against very large units.
  • Is metric to list all prefixes? ..., nm, μm, mm, cm, dm, m, dam, hm, km, Mm, Gm, Tm, ... ; can easily become overwhelming.
  • Creating an interface to manage such a feature may actually be more complicated then the "current support"
I do understand the appeal; you could also explore using sys() to report your units if you are trying to achieve a dual units effect (seams to work 'okay' for simple/base units):
- Kenny Lemens, P.E. ᵂᴵ
Offline OchkovVF
#5 Posted : 05 May 2023 08:15:06(UTC)
OchkovVF
You can use old method!
