SMath Studio Forum
Questions
Speeding up calculation time for Monte Carlo simulations
Joined: 21/11/2023(UTC) Posts: 24 Was thanked: 2 time(s) in 2 post(s)
Hi all, I don't even know if this is possible, but I figured I would ask anyways to see if someone might know any tricks. I wrote a worksheet to show my students an example of a method for making probabilistic calculations of a parameter instead of using deterministic methods. The probabilistic calculation using Monte Carlo simulation lends itself to calculating probability of failure, which is a nice way of explaining system reliability. Ideally, one would run a large number of simulations so that the result converges. However, it seems like the matrix calculations (or at least the way I am doing them) are quite slow, and when I assign a meaningful number of trials (say, 1000 or more), it takes the worksheet forever to calculate. I can do the same in Excel and it is almost instantaneous to do even 10000 or 20000 trials, but I hate doing these in Excel since I can show the work and the equations much more easily with SMath. Any suggestions on what might speed up the run-time? The worksheet is attached for reference. Thanks! FT Correlated Normal Variables - Bearing Capacity Example.sm (418kb) downloaded 13 time(s).
You just have to switch all cells to numeric optimization (Ctrl A to select everything, right mouse button on any cell, select Optimization> Numeric Then, with 10000 tries it took a couple of seconds on my 6 years old notebook. Correlated Normal Variables - Bearing Capacity Example_Kr.sm (418kb) downloaded 16 time(s). |
And there it is, easy as that Thank you so much! Originally Posted by: mkraska You just have to switch all cells to numeric optimization (Ctrl A to select everything, right mouse button on any cell, select Optimization> Numeric Then, with 10000 tries it took a couple of seconds on my 6 years old notebook. Correlated Normal Variables - Bearing Capacity Example_Kr.sm (418kb) downloaded 16 time(s).
1 user thanked gth802s for this useful post.
Originally Posted by: gth802s Any suggestions on what might speed up the run-time? The worksheet is attached for reference. The attached document runs Monte-Carlo in two styles. 1. Logistic style 4 s 2. Ordinary style 0.7 s Observe eval(,)Jean Stat Monte Carlo [rlogis] Copy 2.sm (103kb) downloaded 8 time(s).
Thanks for sharing, looks like it will be useful! Originally Posted by: Jean Giraud Originally Posted by: gth802s Any suggestions on what might speed up the run-time? The worksheet is attached for reference. The attached document runs Monte-Carlo in two styles. 1. Logistic style 4 s 2. Ordinary style 0.7 s Observe eval(,)Jean Stat Monte Carlo [rlogis] Copy 2.sm (103kb) downloaded 8 time(s).
SMath Studio Forum
Questions
