Offline gth802s
#1 Posted : 01 December 2023 10:41:02(UTC)
gth802s
Rank: Member
United States
Was thanked: 2 time(s) in 2 post(s)
Hi all, I don't even know if this is possible, but I figured I would ask anyways to see if someone might know any tricks.
I wrote a worksheet to show my students an example of a method for making probabilistic calculations of a parameter instead of using deterministic methods. The probabilistic calculation using Monte Carlo simulation lends itself to calculating probability of failure, which is a nice way of explaining system reliability.
Ideally, one would run a large number of simulations so that the result converges. However, it seems like the matrix calculations (or at least the way I am doing them) are quite slow, and when I assign a meaningful number of trials (say, 1000 or more), it takes the worksheet forever to calculate. I can do the same in Excel and it is almost instantaneous to do even 10000 or 20000 trials, but I hate doing these in Excel since I can show the work and the equations much more easily with SMath.
Any suggestions on what might speed up the run-time? The worksheet is attached for reference.
Thanks!
FT
Correlated Normal Variables - Bearing Capacity Example.sm (418kb) downloaded 13 time(s).
#2 Posted : 01 December 2023 10:51:42(UTC)
You just have to switch all cells to numeric optimization (Ctrl A to select everything, right mouse button on any cell, select Optimization> Numeric
Then, with 10000 tries it took a couple of seconds on my 6 years old notebook.
Correlated Normal Variables - Bearing Capacity Example_Kr.sm (418kb) downloaded 16 time(s).
on 01/12/2023(UTC)
Offline gth802s
#3 Posted : 01 December 2023 10:55:34(UTC)
gth802s
Rank: Member
United States
And there it is, easy as that Clap Thank you so much!
thanks 1 user thanked gth802s for this useful post.
on 01/12/2023(UTC)
#4 Posted : 02 December 2023 07:35:02(UTC)
The attached document runs Monte-Carlo in two styles.
1. Logistic style 4 s
2. Ordinary style 0.7 s
Observe eval(,)
Stat Monte Carlo [rlogis] Copy 2.sm (103kb) downloaded 8 time(s).
Offline gth802s
#5 Posted : 02 December 2023 07:45:46(UTC)
gth802s
Rank: Member
United States
Thanks for sharing, looks like it will be useful!
Observe eval(,)
