SMath Studio Forum
Questions
How can I use not a for but a while cycle?
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 348 Was thanked: 28 time(s) in 27 post(s)
See please the attached file. Newton.sm (24kb) downloaded 9 time(s).
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings, Instead of using for(3); you can use for(4): for ▮, ▮, ▮ ▮ The four parameter 「 for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} ) "For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions." example:for i:=1, i<10, i:=i+2 k:=2*i Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP! May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
1 user thanked Kenny Lemens for this useful post.
Joined: 26/07/2022(UTC) Posts: 37 Location: UK Was thanked: 24 time(s) in 21 post(s)
1 user thanked StvMath for this useful post.
Roots vs Newton 2-17.png (709kb) downloaded 8 time(s).
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values. mNewton.sm (17kb) downloaded 4 time(s). |
SMath Studio Forum
Questions
