Offline OchkovVF
#1 Posted : 10 February 2024 03:27:16(UTC)
OchkovVF
Was thanked: 39 time(s) in 37 post(s)
See please the attached file. Newton.sm (24kb) downloaded 10 time(s).
Offline Kenny Lemens
#2 Posted : 10 February 2024 05:38:00(UTC)
Kenny Lemens
United States
Was thanked: 67 time(s) in 42 post(s)
Greetings,
Instead of using for(3); you can use for(4):
for ▮, ▮, ▮
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
   k:=2*i
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
thanks 1 user thanked Kenny Lemens for this useful post.
on 10/02/2024(UTC)
Offline OchkovVF
#3 Posted : 10 February 2024 20:38:31(UTC)
OchkovVF
Thanks
But see "???" in the attach
Newton-for-1-2-3-4.sm (27kb) downloaded 7 time(s).
Offline StvMath
#4 Posted : 11 February 2024 00:38:42(UTC)
StvMath
United Kingdom
Was thanked: 30 time(s) in 26 post(s)
Here's a "while" version
Newton-for-1-2-3-4_b.sm (19kb) downloaded 5 time(s).
thanks 1 user thanked StvMath for this useful post.
on 11/02/2024(UTC)
#5 Posted : 11 February 2024 07:58:11(UTC)
Was thanked: 983 time(s) in 811 post(s)
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (53kb) downloaded 5 time(s).
on 11/02/2024(UTC)
Offline OchkovVF
#6 Posted : 11 February 2024 08:53:28(UTC)
OchkovVF
Roots vs Newton
#7 Posted : 11 February 2024 13:55:50(UTC)
Originally Posted by: OchkovVF Go to Quoted Post
oots vs Newton
No interest vs the codes
Offline OchkovVF
#8 Posted : 11 February 2024 19:41:06(UTC)
OchkovVF
Roots vs Newton
https://www.mdpi.com/2227-7390/10/19/3413
#9 Posted : 12 February 2024 03:59:12(UTC)
roots solves Matrix.
Worksheet33.sm (7kb) downloaded 5 time(s).
#10 Posted : 13 February 2024 12:19:59(UTC)
Was thanked: 1150 time(s) in 737 post(s)
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (17kb) downloaded 5 time(s).
on 29/02/2024(UTC)
