#1 Posted : 09 July 2013 17:24:35(UTC)
A simple animation Good
Best Regards,
Davide
File Attachment(s):
AnalogClock.sm (23kb) downloaded 255 time(s).
AnalogClock_viewer.7z (356kb) downloaded 155 time(s).
thanks 4 users thanked Davide Carpi for this useful post.
on 09/07/2013(UTC),  on 09/07/2013(UTC),  on 10/07/2013(UTC),  on 11/07/2013(UTC)
Offline Ber7
#2 Posted : 09 July 2013 23:51:49(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
File Attachment(s):
AnalogClock1.sm (23kb) downloaded 120 time(s).
thanks 2 users thanked Ber7 for this useful post.
on 10/07/2013(UTC),  on 10/07/2013(UTC)
#3 Posted : 10 July 2013 00:20:04(UTC)
Thank you ber,
this make the script faster and easier to read Friends
Best regards,
Davide
P.S. worksheet updated Foto
Offline Ber7
#4 Posted : 11 July 2013 12:37:01(UTC)
Ber7
Israel
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
File Attachment(s):
AnalogClock2.sm (22kb) downloaded 161 time(s).
on 11/07/2013(UTC),  on 11/07/2013(UTC)
#5 Posted : 11 July 2013 15:49:18(UTC)
I see, wonderful Good
#6 Posted : 16 July 2019 06:08:53(UTC)
Best Regards,Ber7.
Glorious old vintage, before I joined Smath.
More elegant needles in there ... needs be animated
attach]31143[/attach]
Offline oscampo
#7 Posted : 18 July 2019 20:24:18(UTC)
oscampo
Colombia
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to Razonar Offline ):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (39kb) downloaded 44 time(s).
click_low.wav (172kb) downloaded 41 time(s).
alarm.wav (892kb) downloaded 39 time(s).
Edited by user 20 July 2019 00:24:52(UTC)  | Reason: Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of
thanks 2 users thanked oscampo for this useful post.
on 18/07/2019(UTC),  on 19/07/2019(UTC)
Offline Razonar
#8 Posted : 19 July 2019 08:25:06(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
thanks 2 users thanked Razonar for this useful post.
on 19/07/2019(UTC),  on 19/07/2019(UTC)
Offline oscampo
#9 Posted : 20 July 2019 00:15:08(UTC)
oscampo
Colombia
Thanks for your suggestions Clap Also I considering the seconds in the movement of the minutes hand for a more realistic appearance.
I've updated the file and I uploaded the new one, you can check it here.
Edited by user 20 July 2019 00:26:23(UTC)  | Reason: Not specified
