A simple animation Best Regards, Davide File Attachment(s): Davide Carpi attached the following image(s): |
4 users thanked Davide Carpi for this useful post.
on 09/07/2013(UTC), on 09/07/2013(UTC), on 10/07/2013(UTC), on 11/07/2013(UTC)
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s). Best Regards,Ber7.
2 users thanked Ber7 for this useful post.
on 10/07/2013(UTC), on 10/07/2013(UTC)
Thank you ber, this make the script faster and easier to read Best regards, Davide P.S. worksheet updated |
Davide,if your program to change the settings a bit, we get "real" analog clock (all the arrows are moving continuously). Best Regards, Ber7
on 11/07/2013(UTC), on 11/07/2013(UTC)
I see, wonderful |
Originally Posted by: Ber7 Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s). Best Regards,Ber7. Glorious old vintage, before I joined Smath. More elegant needles in there ... needs be animated attach]31143[/attach]
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
2 users thanked oscampo for this useful post.
on 18/07/2019(UTC), on 19/07/2019(UTC)
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
on 19/07/2019(UTC), on 19/07/2019(UTC)
Alvaro. Thanks for your suggestions Also I considering the seconds in the movement of the minutes hand for a more realistic appearance. I've updated the file and I uploaded the new one, you can check it here. Edited by user 20 July 2019 00:26:23(UTC)
