Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators:
Administrators
Missing bracket in display of complex numbers with changed units
BTS Issue SS-27
26/06/2013 09:30:13(UTC)
7
1,472
26/06/2013 15:52:34(UTC)
64 bits machine bug (?)
ioan92
ioan92
25/06/2013 18:48:09(UTC)
12
3,519
kilele
26/06/2013 15:50:30(UTC)
roots() bug with a simple linear system of equations
roots() returns "not real roots"
Jarrinator
24/06/2013 04:15:46(UTC)
2
1,239
25/06/2013 11:06:19(UTC)
Fonction Clear
Fonction Clear for matrices do not work
sebast3337
19/06/2013 02:24:50(UTC)
6
1,685
22/06/2013 09:46:10(UTC)
sometimes scalar, sometimes vector??
Different results with symbolic, numeric, eval()
omorr
23/05/2013 11:38:40(UTC)
17
4,693
17/06/2013 22:38:44(UTC)
Inconsistent behaviour when following links
BTS Issues SS-36 and SS-37
16/06/2013 13:24:42(UTC)
4
839
16/06/2013 17:11:30(UTC)
Copying a closed area region crashes SMath
16/06/2013 15:58:47(UTC)
1
1,481
omorr
16/06/2013 16:24:47(UTC)
Empty text regions disappear while editing
BTS Issue SS-49
12/06/2013 03:22:16(UTC)
1
576
14/06/2013 16:05:18(UTC)
User function
ioan92
ioan92
11/06/2013 23:30:40(UTC)
4
962
kilele
12/06/2013 13:59:10(UTC)
links: Worksheet domain doesn't change
09/06/2013 00:58:27(UTC)
1
585
09/06/2013 01:14:35(UTC)
Failed plugin installations cannot be deactivated
BTS Issue SS-50
08/06/2013 01:45:54(UTC)
14
2,309
08/06/2013 19:16:53(UTC)
Extension manager cannot go online
04/06/2013 16:11:48(UTC)
2
1,055
05/06/2013 18:37:09(UTC)
Empty space inserted when collapsed region is deleted
BTS issue SS-51
04/06/2013 02:50:20(UTC)
8
1,694
05/06/2013 02:09:59(UTC)
corrupted file, need help to bring it back
koza
31/05/2013 21:15:37(UTC)
4
1,148
01/06/2013 12:27:58(UTC)
Derivative of hyperbolic secans fails
BTS issue SS-52
31/05/2013 19:57:24(UTC)
1
655
omorr
31/05/2013 20:23:07(UTC)
Guest (5)
New Posts |
No New Posts |
Hot Topic (New Posts) |
Hot Topic |
New Posts (Locked) |
No New Posts (Locked) |
Announcement (New Posts) |
Announcement |
Sticky (New Posts) |
Sticky |
Poll (New Posts) |
Poll |
Moved |
