SMath Studio Forum
Feature Requests
Allow to select result together with units when using customized units
Currently, the custom units of result placeholder has scope of whole expression. So, e.g. trying to select result (15°C) in following line:
288.15*'K=15@'°C
results in whole expression being selected, not only part after "=".
If possible, please enable that selection, to make it easy to copy only result. |
Best regards, Mike Kaganski |
Originally Posted by: mikekaganski copy only result. Maybe like this Mike.
Jean, I think Mike requests something like this: Will check if it is possible to implement
Or something like this.. Best Regards Carlos
on 20/05/2016(UTC), on 20/05/2016(UTC)
Great! In the same time, it made it more convenient to remove result with custom units, if I decided that I don't want to see the result at all with the expression. Before, I needed to remove custom unit explicitly, now I just put cursor to the result and hit Backspace several times.
Thanks again! |
SMath Studio Forum
Feature Requests
