SMath Studio Forum
Questions
Pick a number from a list if condition is meet
Joined: 12/03/2024(UTC) Posts: 10 Was thanked: 1 time(s) in 1 post(s)
How can i pick a speed based on a "n" value. Let's say my n= 13 i want to get the value 30km/h for V, but if its 8 i want 60km/h. I have tried with for/while/if. But im guessing im doing something wrong or i don't know what to write exactly. Any help is much apprecite it!
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
Originally Posted by: mkraska Thank you for the answer, but this doesn't help me. Or i don't understand it . Example, i have N=10, based on N i want to get V. V for N=10 it's from here: , but if i change N to 9 i want to obtain V=30km/hr. Thing is i have 8 variable based on N, and i want to obtain the values only by changing N. Sorry if i don't explain very well.
The procedure is to get a vector of the potential values which can then be accessed by index. You also could implement it as a function v(n) = 30 + mod(n-1, 4)*10 |
Originally Posted by: mkraska The procedure is to get a vector of the potential values which can then be accessed by index. You also could implement it as a function v(n) = 30 + mod(n-1, 4)*10 Great it works now. I just have to figure it out how to implement it for the rest of the file . Thank you very much! How would you tackle this one? Edited by user 13 March 2024 01:42:46(UTC)
Originally Posted by: Obliterate Great it works now. I just have to figure it out how to implement it for the rest of the file . Thank you very much! How would you tackle this one? Divide n by 2, a bit of rounding and offset adjustment should do the job. |
Originally Posted by: mkraska Originally Posted by: Obliterate Great it works now. I just have to figure it out how to implement it for the rest of the file . Thank you very much! How would you tackle this one? Divide n by 2, a bit of rounding and offset adjustment should do the job. I can't seem to get it to work, and for next examples i need to match it with a list that has some randomnes in number list. Isn't there a way i can create a list of number and if my "n" matches that list then i can get the correct value? I tried with for, if and so on. but im still a newbie in Smath. Thank you once again!
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
If you have a limited set of choiches, this might be a solution. Also, I think Martin has a point, since these "n" values should come from some formula. Edited by user 19 March 2024 04:39:52(UTC)
Originally Posted by: Obliterate Originally Posted by: mkraska Originally Posted by: Obliterate Great it works now. I just have to figure it out how to implement it for the rest of the file . Thank you very much! How would you tackle this one? Divide n by 2, a bit of rounding and offset adjustment should do the job. I can't seem to get it to work, and for next examples i need to match it with a list that has some randomnes in number list. Isn't there a way i can create a list of number and if my "n" matches that list then i can get the correct value? I tried with for, if and so on. but im still a newbie in Smath. Thank you once again! If there is no rule, then you have to provide a vector with values and adress it with index n. A simple lookup table by index. Fill the vector by hand, by reading a file or asking a chatbot. |
Originally Posted by: Davide Carpi If you have a limited set of choiches, this might be a solution. Also, I think Martin has a point, since these "n" values should come from some formula. This works but i have other areas with diferent increment and i can't control them with interval. I will list a few of them: here is 1,2,3 then goes to 16,17,18 then 26,27,28. So i have this interval from the picture above and the one before with "Latimea benzii".
Originally Posted by: Obliterate Originally Posted by: Davide Carpi If you have a limited set of choiches, this might be a solution. Also, I think Martin has a point, since these "n" values should come from some formula. This works but i have other areas with diferent increment and i can't control them with interval. I will list a few of them: here is 1,2,3 then goes to 16,17,18 then 26,27,28. So i have this interval from the picture above and the one before with "Latimea benzii". Found a not very fancy solution, but it works . pick a number from a list.sm (7kb) downloaded 3 time(s).
SMath Studio Forum
Questions
