Offline Obliterate
#1 Posted : 12 March 2024 21:31:22(UTC)
Obliterate
Rank: Member
Romania
How can i pick a speed based on a "n" value.
Let's say my n= 13 i want to get the value 30km/h for V, but if its 8 i want 60km/h.
I have tried with for/while/if. But im guessing im doing something wrong or i don't know what to write exactly.
Any help is much apprecite it!
Online mkraska
#2 Posted : 12 March 2024 23:18:17(UTC)
Worksheet6.sm (5kb) downloaded 3 time(s).
Offline Obliterate
#3 Posted : 12 March 2024 23:41:24(UTC)
Obliterate
Rank: Member
Romania
Thank you for the answer, but this doesn't help me. Or i don't understand it Good.
Example, i have N=10, based on N i want to get V. V for N=10 it's from here:
, but if i change N to 9 i want to obtain V=30km/hr.
Thing is i have 8 variable based on N, and i want to obtain the values only by changing N.
Sorry if i don't explain very well.
Online mkraska
#4 Posted : 13 March 2024 00:28:42(UTC)
The procedure is to get a vector of the potential values which can then be accessed by index.
You also could implement it as a function v(n) = 30 + mod(n-1, 4)*10
Offline Obliterate
#5 Posted : 13 March 2024 00:51:40(UTC)
Obliterate
Rank: Member
Romania
Great it works now. I just have to figure it out how to implement it for the rest of the file Biggrin.
Thank you very much!
How would you tackle this one?
Edited by user 13 March 2024 01:42:46(UTC)  | Reason: Not specified
Online mkraska
#6 Posted : 13 March 2024 02:52:27(UTC)
Divide n by 2, a bit of rounding and offset adjustment should do the job.
Offline Obliterate
#7 Posted : 19 March 2024 02:26:30(UTC)
Obliterate
Rank: Member
Romania
I can't seem to get it to work, and for next examples i need to match it with a list that has some randomnes in number list. Isn't there a way i can create a list of number and if my "n" matches that list then i can get the correct value? I tried with for, if and so on. but im still a newbie in Smath.
Thank you once again!
#8 Posted : 19 March 2024 03:19:04(UTC)
If you have a limited set of choiches, this might be a solution.
Also, I think Martin has a point, since these "n" values should come from some formula.
Edited by user 19 March 2024 04:39:52(UTC)  | Reason: Not specified
Online mkraska
#9 Posted : 19 March 2024 08:10:00(UTC)
If there is no rule, then you have to provide a vector with values and adress it with index n. A simple lookup table by index. Fill the vector by hand, by reading a file or asking a chatbot.
Offline Obliterate
#10 Posted : 19 March 2024 20:49:03(UTC)
Obliterate
Rank: Member
Romania
This works but i have other areas with diferent increment and i can't control them with interval. I will list a few of them:
here is 1,2,3 then goes to 16,17,18 then 26,27,28.
So i have this interval from the picture above and the one before with "Latimea benzii".
Offline Obliterate
#11 Posted : 19 March 2024 21:57:49(UTC)
Obliterate
Rank: Member
Romania
Found a not very fancy solution, but it works Good.
pick a number from a list.sm (7kb) downloaded 3 time(s).
