Joined: 15/04/2012(UTC) Posts: 2,048  Was thanked: 1177 time(s) in 752 post(s)
Originally Posted by: w3b5urf3r_reloaded  I can do it, but are you sure? if you want just to resize the region and you go outside the placeholders, the region will resize (just to ask, I agree with the "less things as possible" approach)... OK, then how about double-click? If you can resize by mouse action all over the region, why do you need the placeholders? Resizing just by dragging any point inside would be easier than to point at the tiny markers... BTW, if the image is displayed using an image region (by uni), then the image export is silently blocked for the rest of the session, even if the image region is removed afterwards. This might as well happen if other software has the images open. Thus I would recommend to issue an error message if export fails (if that can be checked). |
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,736   Location: Italy Was thanked: 1405 time(s) in 914 post(s)
Double click seems a good solution, at least as idea... I don't know if the image region causes issues.... Btw export reports are available in the bottom left corner of smath
Originally Posted by: w3b5urf3r_reloaded  Btw export reports are available in the bottom left corner of smath
Cool. BTW: The region is not Ctrl-drag-proof. Edited by user 25 September 2013 23:11:38(UTC)
Originally Posted by: mkraska  BTW: The region is not Ctrl-drag-proof. What's the issue with ctrl+drag? |
Was thanked: 133 time(s) in 114 post(s)
what is supposed to do ctrl+drag ? something wrong happens to me with this key combination: after a ctr+drag one more frame is created, see the problem in this video. I'm using the unofficial portable version. http://screencast-o-matic.com/watch/cIQTrhVm8VEdited by user 26 September 2013 00:16:54(UTC)
Originally Posted by: w3b5urf3r_reloaded  What's the issue with ctrl+drag? Sorry for being unspecific, see attachment. To relieve you have to press continue and then ESC to drop the copy operation. mkraska attached the following image(s): |
Originally Posted by: kilele  done see the post above mhhh... Isn't the same behavior of other regions? Originally Posted by: mkraska  Sorry for being unspecific, see attachment. To relieve you have to press continue and then ESC to drop the copy operation. Found & Fixed, thank you  |
Handbook page for Snapshot region added. @kilele: your video shows, that you are writing a snapshot doc as well, is that right? If so, how about a bit of co-ordination? I really do not insist on documenting everything myself and would be happy to integrate contributions to the activebook (can be done via SVN). There is plenty of white spots, a lot of work yet to do... |
Originally Posted by: mkraska  Handbook page for Snapshot region added.
@kilele: your video shows, that you are writing a snapshot doc as well, is that right? If so, how about a bit of co-ordination? I really do not insist on documenting everything myself and would be happy to integrate contributions to the activebook (can be done via SVN). There is plenty of white spots, a lot of work yet to do... Is my plugin reference's sheet, I'll send you a link  |
sorry for the confusion, didn't know what ctr+drag was for, now I can see that the region can be dragged around without problems
 1 user thanked kilele for this useful post.
I'd propose to write the export files with white background instead of translucent. Perhaps this might be an option. The problem shown in the attached image could also be solved by the image region providing white background. But that would not be entirely equivalent, because the Image region is currently unaware of the image dimensions. mkraska attached the following image(s): |
Originally Posted by: mkraska  I'd propose to write the export files with white background instead of translucent. Perhaps this might be an option. The problem shown in the attached image could also be solved by the image region providing white background. But that would not be entirely equivalent, because the Image region is currently unaware of the image dimensions. That's an image region feature, the exported PNGs are not transparents (try yourself opening the images with an image editor) |
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,641   Was thanked: 1400 time(s) in 817 post(s)
Yes, Davide is right, I make image transparent, removing the white background. |
Russia ☠forever (git.io/vOZo0) Viacheslav N. Mezentsev |
UPDATED- version 1.0.* (password is no more required); - Double-click over the region to make the region compact/fullsize; - Added Spanish translations (thanks to kilele); - Fixed Italian and German translations (thanks to Martin Kraska); - Fixed crashes due to wrong handling of exceptions' propagations; - minor changes. Edited by user 15 October 2013 12:56:03(UTC)
UPDATED- Added "copy to clipboard" edit: documentation & translation sheet updated (look at the first post)Edited by user 23 December 2013 01:28:59(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
If a file with Snapshot regions is opened and then saved at a different location, the default snapshot save path still points to the location of the original file. I propose to change this such that default save location is always the directory where the SMath sheet resides. |
I've updated the plugin. The file needs to be refreshed after the save in the new location to have the path updated ( bug alredy reported) |
UPDATED
- SMath Studio 0.96.5146 required - German translation updated with latest strings
best regards,
Davide |
UPDATED
- Paste as SMath string temporary disabled (this let you paste strings on the canvas freely) |
I experience an "insufficient memory" error when exporting "all" snapshots in the attached sheet. It is possible to recover from the error message. Individual export works.
Informationen über das Aufrufen von JIT-Debuggen anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext ************** System.OutOfMemoryException: Nicht genügend Arbeitsspeicher. bei System.Drawing.Bitmap.Clone(RectangleF rect, PixelFormat format) bei SnapshotRegion.Implementer.ExportSnapshots(MenuButtonArgs args, ExportSet flag) bei ..(Object , RegionBase , MenuButton ) bei ...(Object , EventArgs ) bei System.Windows.Forms.MenuItem.OnClick(EventArgs e) bei System.Windows.Forms.Command.Invoke() bei System.Windows.Forms.Control.WmCommand(Message& m) bei System.Windows.Forms.Control.WndProc(Message& m) bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys ************** mscorlib Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll.
SMathStudio_Desktop Assembly-Version: 0.97.5154.6566. Win32-Version: 1.1.27.0. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMathStudio_Desktop.exe.
System.Windows.Forms Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
System.Drawing Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
ioman Assembly-Version: 0.97.5154.6193. Win32-Version: 0.97.5154.6193. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/ioman.DLL.
System.Windows.Forms.resources Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5420 (Win7SP1.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
canvas Assembly-Version: 0.97.5154.6194. Win32-Version: 0.97.5154.6194. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/canvas.DLL.
rview Assembly-Version: 0.97.5154.6223. Win32-Version: 0.97.5154.6223. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/rview.DLL.
System.Xml Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll.
MathcadFileAccess Assembly-Version: 1.0.5036.4937. Win32-Version: 1.0.5036.4937. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/02a1c2c5-590e-46bb-bcf6-c87856a8b14b/1.0.5036.4937/MathcadFileAccess.dll.
NuLib Assembly-Version: 1.64.5154.6194. Win32-Version: 1.64.5154.6194. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/NuLib.DLL.
SliderRegion Assembly-Version: 0.1.5177.6941. Win32-Version: 0.1.5177.6941. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/0c864749-6fe8-4f62-a74d-f6ac601e52a5/0.1.5177.6941/SliderRegion.dll.
CustomFunctions Assembly-Version: 1.0.5177.39372. Win32-Version: 1.0.5177.39372. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/18dadffd-79a3-4cf9-aee1-d66deb0ea720/1.0.5177.39372/CustomFunctions.dll.
FIRFilterDesign Assembly-Version: 1.0.4972.7542. Win32-Version: 1.0.4972.7542. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/191f7c7a-6b6e-4af0-8bb7-c7a202d59cd4/1.0.4972.7542/FIRFilterDesign.dll.
3DPlotRegion Assembly-Version: 0.1.5161.27307. Win32-Version: 0.1.5161.27307. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/2427d808-1e5e-4ae0-88bf-bc271664a3ab/0.1.5161.27307/3DPlotRegion.dll.
System.Design Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
FunctionsExtension Assembly-Version: 0.0.5093.5251. Win32-Version: 0.0.5093.5251. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/24c691c1-37f2-49e3-9a84-ccb77304d14a/0.0.5093.5251/FunctionsExtension.dll.
ComboBoxRegion Assembly-Version: 0.1.5146.31497. Win32-Version: 0.1.5146.31497. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/28ea70bd-1dee-4200-b2e1-1d53d5832487/0.1.5146.31497/ComboBoxRegion.dll.
SMathFinancials Assembly-Version: 1.0.4928.30282. Win32-Version: 1.0.4928.30282. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/36acfa39-f2ec-4733-9b68-6f96426f672a/1.0.4928.30282/SMathFinancials.dll.
NumericUpDownRegion Assembly-Version: 0.1.5171.2523. Win32-Version: 0.1.5171.2523. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/43438e49-5428-4036-8991-ce03b1d1e572/0.1.5171.2523/NumericUpDownRegion.dll.
MaximaPlugin Assembly-Version: 1.97.5154.32221. Win32-Version: 1.0.0.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.97.5154.32221/MaximaPlugin.dll.
HyperlinkRegion Assembly-Version: 1.0.5177.32144. Win32-Version: 1.0.5177.32144. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4938d1a8-ad11-4de8-afbf-d76d069cfbf8/1.0.5177.32144/HyperlinkRegion.dll.
MatlabCppMathLibrary Assembly-Version: 1.0.4987.26944. Win32-Version: 1.0.4987.26944. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4c2faab1-4d93-4904-8d88-a4e21512d179/1.0.4987.26944/MatlabCppMathLibrary.dll.
TableRegion Assembly-Version: 0.1.5162.30215. Win32-Version: 0.1.5162.30215. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/51fec712-ec75-4551-a13e-478d375ae8d6/0.1.5162.30215/TableRegion.dll.
CurrencyUnits Assembly-Version: 0.1.5117.2578. Win32-Version: 0.1.5117.2578. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dbac4cd-5f31-4a17-982e-f3233b0546de/0.1.5117.2578/CurrencyUnits.dll.
System.Configuration Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
mscorlib.resources Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll.
DataExchange Assembly-Version: 1.0.5172.2758. Win32-Version: 1.0.5172.2758. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5172.2758/DataExchange.dll.
Ionic.Zip Assembly-Version: 1.9.1.8. Win32-Version: 1.9.1.8. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5172.2758/Ionic.Zip.dll.
NonlinearSolvers Assembly-Version: 1.0.9999.5. Win32-Version: 1.0.9999.5. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/618b7e96-330a-406a-b055-9e577672f0b8/1.0.9999.5/NonlinearSolvers.dll.
ClosedXML Assembly-Version: 0.68.1.0. Win32-Version: 0.68.1.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/ClosedXML.dll.
DocumentFormat.OpenXml Assembly-Version: 2.0.5022.0. Win32-Version: 2.0.5022.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/DocumentFormat.OpenXml.DLL.
System.Core Assembly-Version: 3.5.0.0. Win32-Version: 3.5.30729.5420 built by: Win7SP1. CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll.
WindowsBase Assembly-Version: 3.0.0.0. Win32-Version: 3.0.6920.5453 built by: Win7SP1GDR. CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll.
XlsxImportExport Assembly-Version: 1.0.4909.14933. Win32-Version: 1.0.4909.14933. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/XlsxImportExport.dll.
ImageRegion Assembly-Version: 1.0.5149.39321. Win32-Version: 1.0.5149.39321. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/ImageRegion.dll.
SharpVectors.Core Assembly-Version: 0.3.1.1588. Win32-Version: 0.3.1.1588. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Core.dll.
SharpVectors.Css Assembly-Version: 0.3.1.1590. Win32-Version: 0.3.1.1590. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Css.dll.
SharpVectors.Dom Assembly-Version: 0.3.1.1589. Win32-Version: 0.3.1.1589. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Dom.DLL.
SharpVectors.Model Assembly-Version: 0.3.1.1592. Win32-Version: 0.3.1.1592. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Model.dll.
SharpVectors.Rendering.Gdi Assembly-Version: 0.3.1.1595. Win32-Version: 0.3.1.1595. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Rendering.Gdi.dll.
StatisticalTools Assembly-Version: 1.0.4902.38391. Win32-Version: 1.0.4902.38391. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/76f6e9f5-ac86-4ffb-9e4d-284c8daecaf9/1.0.4902.38391/StatisticalTools.dll.
ExcelFileType Assembly-Version: 1.3.5031.1884. Win32-Version: 1.3.5031.1884. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/ExcelFileType.dll.
ICSharpCode.SharpZipLib Assembly-Version: 0.86.0.518. Win32-Version: 0.86.0.518. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/ICSharpCode.SharpZipLib.dll.
NPOI Assembly-Version: 2.0.1.0. Win32-Version: 2.0.1.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.dll.
NPOI.OOXML Assembly-Version: 2.0.1.0. Win32-Version: 2.0.1.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OOXML.dll.
NPOI.OpenXmlFormats Assembly-Version: 2.0.1.0. Win32-Version: 2.0.1.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OpenXmlFormats.DLL.
NPOI.OpenXml4Net Assembly-Version: 2.0.1.0. Win32-Version: 2.0.1.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OpenXml4Net.dll.
AlgLib Assembly-Version: 1.0.4972.7412. Win32-Version: 1.0.4972.7412. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/8e40b49c-3681-4332-903d-751303860e7b/1.0.4972.7412/AlgLib.dll.
SnapshotRegion Assembly-Version: 1.0.5157.476. Win32-Version: 1.0.5157.476. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/9166ba14-4cd9-47f6-b988-e96526b16cc9/1.0.5157.476/SnapshotRegion.dll.
mcadefi Assembly-Version: 1.0.4977.35617. Win32-Version: 1.0.4977.35617. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/91a20d24-c30b-4774-9b1b-4d502a80420f/1.0.4977.35617/mcadefi.dll.
ICSharpCode.SharpZipLib Assembly-Version: 0.86.0.518. Win32-Version: 1.0.4977.35617. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/91a20d24-c30b-4774-9b1b-4d502a80420f/1.0.4977.35617/mcadefi.dll.
CFLabelRegion Assembly-Version: 1.0.5157.770. Win32-Version: 1.0.5157.770. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/a43ac8f9-29d7-4e8a-9ad0-82cf7c4e14f6/1.0.5157.770/CFLabelRegion.dll.
TextRegionUtilities Assembly-Version: 0.1.5176.21422. Win32-Version: 0.1.5176.21422. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/a9f5e37d-83f5-4a4b-a106-0ba7b202abbb/0.1.5176.21422/TextRegionUtilities.dll.
PdfFileType Assembly-Version: 1.0.5146.31046. Win32-Version: 1.0.5146.31046. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.5146.31046/PdfFileType.dll.
PdfSharp Assembly-Version: 1.32.2608.0. Win32-Version: 1.32.2608.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.5146.31046/PdfSharp.dll.
CheckBoxRegion Assembly-Version: 1.0.5146.31372. Win32-Version: 1.0.5146.31372. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/aeb799ab-3afc-4a82-8f44-27d03df672ca/1.0.5146.31372/CheckBoxRegion.dll.
XYPlotRegion Assembly-Version: 0.1.5151.38078. Win32-Version: 0.1.5151.38078. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/c12231ec-4873-43c1-a7d0-a167ebd17066/0.1.5151.38078/XYPlotRegion.dll.
ModellerRegion Assembly-Version: 1.0.5147.447. Win32-Version: 1.0.5147.447. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.5147.447/ModellerRegion.dll.
netDxf Assembly-Version: 0.1.2.0. Win32-Version: 0.1.2.0. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.5147.447/netDxf.dll.
GPCWrapper Assembly-Version: 1.0.4914.35302. Win32-Version: 1.0.4914.35302. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f01/1.0.4914.35302/GPCWrapper.dll.
iode64 Assembly-Version: 1.0.4975.7445. Win32-Version: . CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/1.0.4975.7557/iode.dll.
ODESolvers Assembly-Version: 1.0.4975.7557. Win32-Version: 1.0.4975.7557. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/1.0.4975.7557/ODESolvers.dll.
msvcm90 Assembly-Version: 9.0.30729.6161. Win32-Version: 9.00.30729.6161. CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll.
include Assembly-Version: 1.0.5082.41871. Win32-Version: 1.0.5082.41871. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/dfdcd1f7-5005-45f1-8bf8-016fb072ccf3/1.0.5082.41871/include.dll.
DevelopmentTools Assembly-Version: 0.1.5156.42223. Win32-Version: 0.1.5156.42223. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/f406188b-ff0e-4b02-8b05-8d6fda91e357/0.1.5156.42223/DevelopmentTools.dll.
GNUScientificLibrary Assembly-Version: 1.0.4988.38288. Win32-Version: 1.0.4988.38288. CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.4988.38288/GNUScientificLibrary.dll.
gsl Assembly-Version: 1.0.4988.38244. Win32-Version: . CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.4988.38288/gsl64.dll.
HTMLFileType Assembly-Version: 1.13.5154.6538. Win32-Version: 1.13.5154.6538. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/HTMLFileType.dll.
ImageFileType Assembly-Version: 1.9.5154.6541. Win32-Version: 1.9.5154.6541. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ImageFileType.dll.
PictureRegion Assembly-Version: 1.10.5154.6544. Win32-Version: 1.10.5154.6544. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PictureRegion.dll.
PlotRegion Assembly-Version: 1.9.5154.6547. Win32-Version: 1.9.5154.6547. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PlotRegion.dll.
SMathFileType Assembly-Version: 1.9.5154.6550. Win32-Version: 1.9.5154.6550. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SMathFileType.dll.
SpecialFunctions Assembly-Version: 1.11.5154.6552. Win32-Version: 1.11.5154.6552. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SpecialFunctions.dll.
TextRegion Assembly-Version: 1.10.5154.6555. Win32-Version: 1.10.5154.6555. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/TextRegion.dll.
ViewerFileType Assembly-Version: 1.1.5154.6559. Win32-Version: 1.1.5154.6559. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ViewerFileType.dll.
XMCDFileType Assembly-Version: 1.12.5154.6563. Win32-Version: 1.12.5154.6563. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/XMCDFileType.dll.
2xwrdnrd Assembly-Version: 0.97.5154.6566. Win32-Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
SyLib Assembly-Version: 1.31.5154.6193. Win32-Version: 1.31.5154.6193. CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SyLib.DLL.
System.Drawing.resources Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5420 (Win7SP1.050727-5400). CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing.resources/2.0.0.0_de_b03f5f7f11d50a3a/System.Drawing.resources.dll.
************** JIT-Debuggen ************** Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der Konfigurationsdatei der Anwendung oder des Computers (machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden. Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten Ausnahmen an den JIT-Debugger gesendet, der auf dem Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
File Attachment(s): mkraska attached the following image(s): |
