Hi everybody, I am a very new user of SMath. I created an sm file for calculating stiffness matrix of a beam. After I ran the program I was trying to change one input format and I suddenly closed the sm file before it finished calculating. After doing that I am no more able to open my previous sm file. The error message is " Unexpected end of file has occurred. The following elements are not closed: result, math, region, regions. line 46280, position 26". If anybody know how to retrieve the old file Please help me.....
Joined: 19/01/2012(UTC) Posts: 12 Was thanked: 3 time(s) in 2 post(s)
Hi Samira,
I already faced the same problem. If you do not have a backup, there is no way to restore the file. This is a bug within SMath. Avoid saving the worksheet while it is calculating or train yourself to click the "Interrupt processing" button before you click the save button. Infinity
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Originally Posted by: Samira Hi everybody, I am a very new user of SMath. I created an sm file for calculating stiffness matrix of a beam. After I ran the program I was trying to change one input format and I suddenly closed the sm file before it finished calculating. After doing that I am no more able to open my previous sm file. The error message is " Unexpected end of file has occurred. The following elements are not closed: result, math, region, regions. line 46280, position 26". If anybody know how to retrieve the old file Please help me..... Please attach your damaged file to the post, we can recover a part of it (see here) regards, w3b5urf3r Edited by user 12 September 2012 11:20:03(UTC)
Hi I have a similar error my file wont open with the unexpected end of file error. I have attached it if possible it will be appreciated if you could try recover it. Dane
Done! Edited by user 20 May 2016 22:45:13(UTC)
| Reason: marked as solved |
Crashing unexpetedly is not particular to Smath. Often, it's not possible to trace the cause. In that respect, Smath is superior to Mathcad, you lose only what has not been saved, but that may depend upon your PC version. With XP, the most recent restore point is not far from where it crashed.
jmG
