Joined: 01/02/2018(UTC) Posts: 3 Was thanked: 1 time(s) in 1 post(s)
Hi, I was very glad to find this SMath lately that has nearly everything covered I used previously in MC. But I cannot believe that the plotting functionality is stuck in a very rudimentary form. Not beeing able to set the axis limits programmatically but only by scrolling is truly a p-i-t-a! Displaying a sine between -10 and 10 is for school kids. If my data's x-region is between 1000000 and 1000010 or between 1E-9 and 1.0001E-9 I have to scroll like crazy to find the graphs. Sorry. And logarithmic axis scaling is a must too. And I liked actually MCs ability to use some range variable to define the x-axis and using y-vectors without having to create matrices out of every y-vector. People have made so many extensions to SMath, could someone please please integrate a plot region with basic functionality! Or at least add a rescale button to zoom into the used ranges...
1 user thanked Propmark for this useful post.
Try a search for SMath Studio Handbuch and follow the link in my signature. |
You have a good point compared to MCD. For those plots that don't plot unless you find the region. you can use the X_Y plot, range the 'x', 'y' at will. On the other hand, MCD [at least up to 15] couldn't be size properly. Handles were ½ pica [6 pixels]. Smath QuickPlot is on pixel and all plots can be sized exactly the same. On the other hand, Smath QuickPlot provides the finest plot on the market [OriginLab is very fine too] compared to Mathcad up to 15 that can't produce fine plot based on ½ pica. There are very many more instances Smath plot are superior to MCD was ... Smath solve lot of stuff directly on the canvas. Personally, I hate Smath on very small values ordinates.
Please, visit "Thermal Physics..." posted last minute. Observe the X_Y plot easy settings X, Y axes.
Originally Posted by: Propmark People have made so many extensions to SMath, could someone please please integrate a plot region with basic functionality! Or at least add a rescale button to zoom into the used ranges.. You are asking a lot for this magnificient freeware that does nearly as much maths than MCD [7 ... 15] Your huge numbers + little, X_Y plot will not like at all and will risk crash. You can always scale the results to more reasonable values. I fact, maths exist only in the range 0 .. 1 The attached shows the water density [kg/m³ <= °C] in the very low range X_Y plot is just gorgeous for that. The Water bar saturation shows how to use logpts to export data adequately populated in the low range. We used the same in Mathcad. Cheers Inst_Water [kg_m3].sm (56kb) downloaded 48 time(s). Inst_Water bar Saturation [tdegC].sm (52kb) downloaded 30 time(s).
Joined: 01/08/2010(UTC) Posts: 115 Location: Rome Was thanked: 13 time(s) in 13 post(s)
I agree completely with the request of Propmark and my modest opinion is the following; as soon as it as been consolidated this period of development mainly devoted to the improvements on the documents formatting part of the documents in Smath I guess that same time has to be devoted to improvements of on the Graphs side both on the default types mode made available and both making some internal improvements (API ? or other aspects of the Smath engine I am not a master about) that will allow Uni or other people that have developed several Graph oriented Plug-in to push further ahead their development( at least is what I have understood reading several forum part devoted to this topic ) .
Franco
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
about limits, from the discusion on integration with microMathematics Plus Originally Posted by: Andrey Ivashov And also (less visible for end users): Internally built-in Graphs now supports plots visualization with respect to limits set for axes. Also, I'm working to create a set of 2D charts with common features, first planned is a bar chart:
Edited by user 02 February 2018 12:17:18(UTC)
3 users thanked Davide Carpi for this useful post.
on 02/02/2018(UTC), on 02/02/2018(UTC), on 02/02/2018(UTC)
Thank you for all your responses, I'll need some time to try out the recommendations like X_Yplot, Maxima-Draw2D and so on...
Davide,
really very interesting what is shown as a preview in your mail. Keep up the good work and best regards
Franco
