2 Pages12>
Offline overlord
#1 Posted : 30 August 2019 14:52:43(UTC)
Turkey
I have been trying to make this code work for two days.
Actually it is a C code which I am trying to implicate to SMath. C code is also included and runs perfectly.
In SMath, code works to a point actually. When I debug it I can see it can assign numbers, backtrack if there is no option.
So SMath code also seems legit but eventually the algorithm just stop working. No error no significant reason.
With different puzzles, code terminated at different places at middle of calculation.
I couldn't figure out what is wrong. Is it a bug or my coding is insufficient?
Any help should be appreciated.
Regards.
sudoku.sm (27kb) downloaded 39 time(s).
sudoku.7z (39kb) downloaded 19 time(s).
Offline alyles
#2 Posted : 30 August 2019 19:06:01(UTC)
alyles
United States
I posted something very inaccurate before and have since deleted it. However, in my testing, it seems that it's not dependent on the number of iterations. The function seems to stop when rw,cl get to around 2,4 or 2,5. This is independent of the number of function calls to fillSudoku.
Offline alyles
#3 Posted : 30 August 2019 19:18:25(UTC)
alyles
United States
This looks to correlate to a depth of ~21 or 22 levels of recursion no matter the starting puzzle.
#4 Posted : 30 August 2019 19:44:22(UTC)
I never heard of Sudoku. As it looks, you first scan for coincidence.
Can it relate to some truth table ? Then else game ... !
#5 Posted : 30 August 2019 19:47:06(UTC)
... your original creates "critical error", that can be repaired in the first module.
#6 Posted : 30 August 2019 19:51:21(UTC)
Sudoku First Module.sm (18kb) downloaded 12 time(s).
#7 Posted : 30 August 2019 20:09:53(UTC)
... make sure you completely understand the Bolean
from the code you imitate. As corrected, red.
Red may mean not winning ?
sudoku Freak.sm (24kb) downloaded 15 time(s).
Offline alyles
#8 Posted : 30 August 2019 21:25:01(UTC)
alyles
United States
To better illustrate what I think is happening I've created the following worksheet. The first function definition is just a simple function that calls itself recursively until its 200th call at which point it exits. However, when run it experiences the same error as we see in the sudoku.sm. I rewrote the function using a try/on error and we see we only get to 50 iterations before it fails.
recursion.sm (5kb) downloaded 13 time(s).
Offline overlord
#9 Posted : 30 August 2019 22:14:24(UTC)
Turkey
What I understood considering your last messages, you think there is nothing significant wrong with the code itself. Problem is SMath handling of recursions.
So, it comes forward that is why I wouldn't be able to make an SMath Sudoku Solver with recursion.
Thank you Alyles.
Edited by user 09 July 2021 01:22:14(UTC)  | Reason: Not specified
#10 Posted : 31 August 2019 01:41:02(UTC)
I think it's possible to fill the '0' positions of the 9x9 Sudoku
with random not common to the existing filled position.
Filling one col at time, collect ...
#11 Posted : 31 August 2019 16:50:00(UTC)
So, it comes forward that I wouldn't be able to make an SMath Sudoku Solver.
Thank you Alyles.
I remember this limitation was introduced some time ago to avoid unintentional hard crashes on wrong formed algorithms; considering that any recursive algorithm can be made iterative, you probably have to design it in another way or find a different code Good
on 31/08/2019(UTC)
Offline alyles
#12 Posted : 31 August 2019 17:33:57(UTC)
alyles
United States
As Davide said, you don't have to do it recursively. Biggrin
It may be slow, but it works. Might be able to optimize for better performance.
sudoku_lyles2.sm (29kb) downloaded 21 time(s).
thanks 1 user thanked alyles for this useful post.
on 31/08/2019(UTC)
Offline alyles
#13 Posted : 31 August 2019 17:48:48(UTC)
alyles
United States
Well it works for the first two puzzles at least. Having issues with the third. Haven't tried the fourth....
It's a start
Offline ndtma
#14 Posted : 31 August 2019 18:42:16(UTC)
ndtma
Sri Lanka
It works for the fourth, but fails for the third puzzle.
Offline overlord
#15 Posted : 31 August 2019 19:04:33(UTC)
Turkey
Wow, I didn't know there is a purposed limitation for recursion. For those who knows what they are doing, I think that limit can be removed by adding an extra code at the beginning like (recurselimit:=0), or re-adding the limit (recurselimit:=1).
Yeah it can be made iterative, alyles already did one as far as I can see. I just wanted you guys to check if I did something wrong about my algorithm. I just love recursing, I always feel like it is magical to me. Good
Thank you all guys, regards
Offline overlord
#16 Posted : 31 August 2019 19:31:14(UTC)
Turkey
Don't bother about it. I found these sudoku's on internet without checking them.
I checked that puzzle with C code right now and it has no solution.
#17 Posted : 01 September 2019 00:15:53(UTC)
Confirmed: puzzle 3 fails "Requested matrix does not exist" [q=> 1..99]
Offline Razonar
#18 Posted : 01 September 2019 07:50:14(UTC)
Razonar
Uruguay
Was thanked: 830 time(s) in 526 post(s)
Hi. It exists in other languages. For instance, can see it at https://reference.wolfram.com/language/ref/$RecursionLimit.html
on 01/09/2019(UTC)
#19 Posted : 01 September 2019 16:15:02(UTC)
You mean puzzle 3 has no solution ?
Solution is => give to champions.
Attached utilities may be useful otherwise.
Mathemtica 4.0 "recursion limit" is pure jargon.
In some program, if/otherwise does not work [if/else = YES].
Is there a catch wrt puzzle 3 ... Watson ?
Utilities Matrix Count in Soduku.sm (23kb) downloaded 10 time(s).
Offline Razonar
#20 Posted : 03 September 2019 05:14:14(UTC)
Razonar
Uruguay
Hi. Here, the mathcad 11 version for the recursive method. Notice that mathcad don't pass values by reference, only by value, so the matrix can't be modified inside the fucntion, only 'outside'. Also, mathcad have the return function as keyword but isn't used.
SudokuRec.zip (25kb) downloaded 12 time(s).
SudokuRec.pdf (286kb) downloaded 15 time(s).
This other is te recurrent version in SMath: don't works.
SudokuRec.sm (46kb) downloaded 14 time(s).
This other is a rewrite of the alyles version.
SudokuBruteForce_lyles.sm (44kb) downloaded 26 time(s).
Edited by user 03 September 2019 05:18:41(UTC)  | Reason: Not specified
on 03/09/2019(UTC)
Guest (2)
2 Pages12>
