SMath Studio Forum
Samples
Program for Linear and Polynomial Fit
Simple examples on Linear and Polynomial fittings included as follows. This may be useful for beginners. Examples 1 to 3 are for comparison only. Plot of given data is necessary to guess the distribution. 1. Ex. 1: Quadratic, posted by Martin 2. Ex.2: Ex.1 using SMath 3. Ex.3. Linear 4. Ex.4: A simple program to determine a suitable Linear / Polynomial fit to such data. 1.0 Linear & Poly Fits.sm (739kb) downloaded 68 time(s).Edited by user 08 December 2019 13:18:33(UTC)
1 user thanked ndtma for this useful post.
Originally Posted by: ndtma Simple examples on Linear and Polynomial fittings included as follows. SS 6179 does not open at all and may have crashed my session. If SS 7251 syntax is not compatible, it just turns red. As it looks, incompatible syntax in program is dead like a stone. Voltaire declared [not exactly] ... When a stone is dead, she is dead for a long time !Why not simply open the red syntax program ? The black regions SS 7251 have been reported many times, still pending Doctors to come back from fishing. Thanks Collab NDTMA
Originally Posted by: Jean Giraud SS 6179 does not open at all and may have crashed my session. Sorry Jean. Forgot to attach the PDF. Thanks for your observations. 1.0 Linear & Poly Fits.pdf (684kb) downloaded 60 time(s).Edited by user 08 December 2019 18:52:18(UTC)
Originally Posted by: ndtma Sorry Jean. Forgot to attach the PDF. Thanks for your observations. Thanks for the *.PDF Reconstructed c/w a lot more elegant export Jean. Polyfit Otherwise.sm (16kb) downloaded 39 time(s).
Originally Posted by: Jean Giraud Reconstructed c/w a lot more elegant export J ... a bit more/different but encountered "puzzling or bug". Doctored but mystic. Polyfit Otherwise.sm (23kb) downloaded 26 time(s).
Originally Posted by: Jean Giraud ... a bit more/different but encountered "puzzling or bug". Doctored but mystic. ... suite/reconciliation from SS 5346 [works SS 6179] Elegant and profitable, no bug/puzzling. Export polyfit. Polynomial fit Methods [Regress Quick].sm (18kb) downloaded 44 time(s).
on 09/12/2019(UTC), on 09/12/2019(UTC)
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Hi. This is another approach. PolyFit.sm (19kb) downloaded 45 time(s). PolyFit.pdf (163kb) downloaded 49 time(s).Best regards. Alvaro
3 users thanked Razonar for this useful post.
on 09/12/2019(UTC), on 09/12/2019(UTC), on 09/12/2019(UTC)
Originally Posted by: Razonar This is another approach. Thanks Alvaro ... superb ! Jean. That black regions is really a pen in the ass. PolyFit [Alvaro Balistic].sm (23kb) downloaded 28 time(s).
... added HadCRU [Hadley Climate Research Unit] Global warming 1950 ... 2019 °C deviation wrt period 1950/1960 Fit on ChebyShev ± 1 and recovered on separate document. PolyFit [Alvaro Balistic].sm (134kb) downloaded 18 time(s).
Originally Posted by: Jean Giraud Fit on ChebyShev ± 1 and recovered on separate document. ... here is HadCRU fitted in the ChebyShev ± 1 then recovered in the original 1950 ... 2019 range. It has nothing to do with the PolyFit(X,Y,n) simply that high order polynomials are numerically unstable at high range of the variate 'x'. It has nothing to do with the CAS or floating arithmetic, simply an Edu mathematical fact. PolyFit [Alvaro Balistic].sm (311kb) downloaded 22 time(s).
Originally Posted by: Jean Giraud ... here is HadCRU fitted in the ChebyShev ± 1 ... the clean/refreshed Edu version. PolyFit [Alvaro Balistic].sm (231kb) downloaded 26 time(s).
Originally Posted by: ndtma Simple examples on Linear and Polynomial fittings included as follows. Another methodEdited by user 10 December 2019 19:19:47(UTC)
Originally Posted by: ndtma Simple examples on Linear and Polynomial fittings included as follows. ... tested/fails [Uncertainty] Poly 00 NDTMA.sm (113kb) downloaded 27 time(s).
Originally Posted by: Jean Giraud Originally Posted by: ndtma Simple examples on Linear and Polynomial fittings included as follows. ... tested/fails [Uncertainty] Poly 00 NDTMA.sm (113kb) downloaded 27 time(s). Hi. Here the code (el(x,r)≡0)&(c≡1) for construct the Vandermonde matrix is for avoid 0^0, which returns the error. Also, I avoid augment in the recursive loops because it's frustratingly slow. Finlay, the code for PolyVal it's very inefficient, it's only for pedagogical purposes. Horner must be implemented for some other application. Notice that both are matlab/octave/scilab routines too. In my opinion, the intention of Nugegodage to replicate ms excel results in SMath is very important, to promote SMaths as better alternative to excel doing math. Best regards. Alvaro.
Thank you Jean, Alvaro and Carlos for your valuable responses. BTW, I too get "uncertainty" error in Jean's example. Hope these issues will be resolved soon. Once again Thank You all. |
Hi. R2 like ms excel added. And tome other alternatives for solve the matrix. PolyFit.sm (153kb) downloaded 32 time(s). PolyFit.pdf (694kb) downloaded 28 time(s).Best regards. Alvaro.
Originally Posted by: ndtma Thank you Jean, Alvaro and Carlos for your valuable responses. BTW, I too get "uncertainty" error in Jean's example. Hope these issues will be resolved soon. Resolved in the attached from coding Cholesky the right way. Alvaro code was OK too. All in all, purely polynomials have so few applications that they don't worth more than a short Classroom introduction. On the other hand, the vector of functions is lot more productive. And BTW, it is the form for the Conjugate Gradient model fitting. Jean. Poly 000 jmG Conjugate Gradient.sm (50kb) downloaded 22 time(s). Poly 000 jmG.sm (147kb) downloaded 24 time(s).
Was thanked: 21 time(s) in 17 post(s)
That's my solution - to separate the functions from matrix building, - to use vectorize for speed
Originally Posted by: MarB That's my solution - to separate the functions from matrix building, - to use vectorize for speed Thanks for your effort/contribution. Sorry, but too much of a monkey business. Here are the two elegant Cholesky linear solver: 1. The modular local utility [Mathcad linfit style] 2. The general algo style as an Smath native. Works same SS 6179 from original created SS 5346. Hope this document will tranquilize visitors/users ! Jean. Poly 000 jmG linfit MCD.sm (35kb) downloaded 43 time(s).
SMath Studio Forum
Samples
