2 Pages12>
Offline ndtma
#1 Posted : 08 December 2019 13:12:39(UTC)
ndtma
Sri Lanka
Simple examples on Linear and Polynomial fittings included as follows. This may be useful for beginners.
Examples 1 to 3 are for comparison only. Plot of given data is necessary to guess the distribution.
1. Ex. 1: Quadratic, posted by Martin
2. Ex.2: Ex.1 using SMath
3. Ex.3. Linear
4. Ex.4: A simple program to determine a suitable Linear / Polynomial fit to such data.
1.0 Linear & Poly Fits.sm (739kb) downloaded 69 time(s).
Edited by user 08 December 2019 13:18:33(UTC)  | Reason: Not specified
on 09/12/2019(UTC)
#2 Posted : 08 December 2019 18:12:47(UTC)
SS 6179 does not open at all and may have crashed my session.
If SS 7251 syntax is not compatible, it just turns red.
As it looks, incompatible syntax in program is dead like a stone.
Voltaire declared [not exactly] ...
When a stone is dead, she is dead for a long time !
Why not simply open the red syntax program ?
The black regions SS 7251 have been reported many times,
still pending Doctors to come back from fishing.
Thanks Collab NDTMA
Offline ndtma
#3 Posted : 08 December 2019 18:50:12(UTC)
ndtma
Sri Lanka
Sorry Jean. Forgot to attach the PDF. Thanks for your observations.
1.0 Linear & Poly Fits.pdf (684kb) downloaded 61 time(s).
Edited by user 08 December 2019 18:52:18(UTC)  | Reason: Not specified
on 09/12/2019(UTC)
#4 Posted : 08 December 2019 22:49:45(UTC)
Thanks for the *.PDF
Reconstructed c/w a lot more elegant export
Jean.
Polyfit Otherwise.sm (16kb) downloaded 40 time(s).
#5 Posted : 08 December 2019 23:58:03(UTC)
J
... a bit more/different but encountered "puzzling or bug".
Doctored but mystic.
Polyfit Otherwise.sm (23kb) downloaded 27 time(s).
#6 Posted : 09 December 2019 05:21:29(UTC)
... suite/reconciliation from SS 5346 [works SS 6179]
Elegant and profitable, no bug/puzzling. Export polyfit.
Polynomial fit Methods [Regress Quick].sm (18kb) downloaded 44 time(s).
thanks 2 users thanked Jean Giraud for this useful post.
on 09/12/2019(UTC),  on 09/12/2019(UTC)
Offline Razonar
#7 Posted : 09 December 2019 16:32:33(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi. This is another approach.
PolyFit.sm (19kb) downloaded 46 time(s).
PolyFit.pdf (163kb) downloaded 49 time(s).
thanks 3 users thanked Razonar for this useful post.
on 09/12/2019(UTC),  on 09/12/2019(UTC),  on 09/12/2019(UTC)
#8 Posted : 10 December 2019 03:11:33(UTC)
Thanks Alvaro ... superb ! Jean.
That black regions is really a pen in the ass.
PolyFit [Alvaro Balistic].sm (23kb) downloaded 28 time(s).
#9 Posted : 10 December 2019 05:18:06(UTC)
... added HadCRU [Hadley Climate Research Unit]
Global warming 1950 ... 2019 °C deviation wrt period 1950/1960
Fit on ChebyShev ± 1 and recovered on separate document.
PolyFit [Alvaro Balistic].sm (134kb) downloaded 19 time(s).
#10 Posted : 10 December 2019 08:15:11(UTC)
... here is HadCRU fitted in the ChebyShev ± 1
then recovered in the original 1950 ... 2019 range.
It has nothing to do with the PolyFit(X,Y,n)
simply that high order polynomials are numerically
unstable at high range of the variate 'x'.
It has nothing to do with the CAS or floating arithmetic,
simply an Edu mathematical fact.
PolyFit [Alvaro Balistic].sm (311kb) downloaded 22 time(s).
#11 Posted : 10 December 2019 18:36:43(UTC)
... the clean/refreshed Edu version.
PolyFit [Alvaro Balistic].sm (231kb) downloaded 27 time(s).
Offline ndtma
#12 Posted : 10 December 2019 19:17:44(UTC)
ndtma
Sri Lanka
Another method
Edited by user 10 December 2019 19:19:47(UTC)  | Reason: Not specified
#13 Posted : 11 December 2019 00:14:55(UTC)
... tested/fails [Uncertainty]
Poly 00 NDTMA.sm (113kb) downloaded 27 time(s).
on 11/12/2019(UTC)
Offline Razonar
#14 Posted : 11 December 2019 01:00:23(UTC)
Razonar
Uruguay
Hi. Here
the code (el(x,r)≡0)&(c≡1) for construct the Vandermonde matrix is for avoid 0^0, which returns the error.
Also, I avoid augment in the recursive loops because it's frustratingly slow.
Finlay, the code for PolyVal it's very inefficient, it's only for pedagogical purposes. Horner must be implemented for some other application. Notice that both are matlab/octave/scilab routines too.
In my opinion, the intention of Nugegodage to replicate ms excel results in SMath is very important, to promote SMaths as better alternative to excel doing math.
on 11/12/2019(UTC)
Offline CBG
#15 Posted : 11 December 2019 01:40:48(UTC)
CBG
Same exercises by Cholesky's method.
Cholesky_Function_CBG_Jean_SS7251.sm (169kb) downloaded 27 time(s).
Cholesky_Function_CBG_Jean_SS6179.sm (167kb) downloaded 25 time(s).
thanks 1 user thanked CBG for this useful post.
on 11/12/2019(UTC)
Offline ndtma
#16 Posted : 11 December 2019 05:21:00(UTC)
ndtma
Sri Lanka
Thank you Jean, Alvaro and Carlos for your valuable responses.
BTW, I too get "uncertainty" error in Jean's example. Hope these issues will be resolved soon.
Once again Thank You all.
Offline Razonar
#17 Posted : 11 December 2019 05:58:52(UTC)
Razonar
Uruguay
Hi. R2 like ms excel added. And tome other alternatives for solve the matrix.
PolyFit.sm (153kb) downloaded 32 time(s).
PolyFit.pdf (694kb) downloaded 29 time(s).
#18 Posted : 11 December 2019 07:42:29(UTC)
Resolved in the attached from coding Cholesky the right way.
Alvaro code was OK too.
All in all, purely polynomials have so few applications
that they don't worth more than a short Classroom introduction.
On the other hand, the vector of functions is lot more productive.
And BTW, it is the form for the Conjugate Gradient model fitting.
Jean.
Poly 000 jmG Conjugate Gradient.sm (50kb) downloaded 22 time(s).
Poly 000 jmG.sm (147kb) downloaded 24 time(s).
Offline MarB
#19 Posted : 11 December 2019 11:33:00(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
That's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
#20 Posted : 11 December 2019 17:44:36(UTC)
Originally Posted by: MarB Go to Quoted Post
That's my solution
Thanks for your effort/contribution.
Sorry, but too much of a monkey business.
Here are the two elegant Cholesky linear solver:
1. The modular local utility [Mathcad linfit style]
2. The general algo style as an Smath native.
Works same SS 6179 from original created SS 5346.
Hope this document will tranquilize visitors/users !
Jean.
Poly 000 jmG linfit MCD.sm (35kb) downloaded 43 time(s).
2 Pages12>
