Hi everyone, I have a problem with the equation system shown. does not return any results ... where am I wrong? this is the .sm file sisstema.sm (60kb) downloaded 18 time(s).
You don't use the Solve() function correctly. The second argument is a list of variables (names), not a list of equations. Solve() is a symbolic procedure and doesn't need initial values. In your case, there are two solutions because the variable V appears only squared. Solve returns two lists of equations, which can be applied using Assign() for assignment of the solution variables. |
4 users thanked mkraska for this useful post.
on 17/01/2020(UTC), on 17/01/2020(UTC), on 17/01/2020(UTC), on 17/01/2020(UTC)
