SMath Studio Forum
Questions
Mathcad to SMath_function root and solve
Hi, can someone help me to copy this mathcad code in a SMath's one? I have some problems with the solution of Xn Thank you
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Thank you
Hi. sigma.c fucntion is defined with an if clause. SMath can't integrate it, but you can use cases(): Now you can integrate: Best regards. Alvaro.
Thanks Alvaro. I made your correction, using the function cases(), but I have the same problem if I add other terms to fb(xn), for example if I add Ast*sigma sb(eps) and Asc*sigmasb(eps). How is it possible? Thanks verifica a flessione_prova2.sm (44kb) downloaded 5 time(s).
Joined: 14/09/2013(UTC) Posts: 90 Was thanked: 24 time(s) in 16 post(s)
Possibly an odd bracket problem? Here appears that Smath is making a group of "y+sigma bla bla" as object for the differential operator So, fb(x) could not be evaluated. I placed some brackets to clearly separate "y" from what follows in the equation, see picture below. It appears that with brackets, fb(x) can be evaluated (but I get an error on units). Maybe some other formula needs to be checked before? Ciao! Edited by user 30 March 2021 12:44:22(UTC)
Splitted the equation in three contributions, it appears the the integral is not consistent with other two terms of the sum I think calculation should work, once you clear the unit issue which is hidden somewhere in other parts of the calculation. Ciao
I am pretty sure my units mismatch correction is not suitable. You should have to check this issue by yourself. But I had managed to solve your function problem. Rewriting it make function tick again. Regards verifica a flessione_prova2_rev.sm (46kb) downloaded 16 time(s).
I've had this pending in background so I'll share the solution even here. Aside the initial issues about if() and units, the integral fails when x_n is set as 0, since epsilon is something/0. Therefore solve range must exclude 0 or the function has to handle it. Happy Easter and take care, anyone. Edited by user 03 April 2021 14:11:18(UTC)
Originally Posted by: Davide Carpi Happy Easter and take care, anyone. Thanks Davide ... Your's all too ... Jean
SMath Studio Forum
Questions
