SMath Studio Forum
Questions
Mathcad to SMath_function root and solve
![Matteo_94 Matteo_94](/forum/images/noavatar.gif) Rank: Newbie
Joined: 26/03/2021(UTC) Posts: 3 ![Italy Italy](/forum/Content/images/flags/IT.png) Location: Roma
Hi, can someone help me to copy this mathcad code in a SMath's one? I have some problems with the solution of Xn Thank you ![Cattura2.PNG](/forum/resource.ashx?a=37096&b=2) ![codice Mathcad.JPG](/forum/resource.ashx?a=37095&b=2)
![Razonar Razonar](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 28/08/2014(UTC) Posts: 1,370 ![Uruguay Uruguay](/forum/Content/images/flags/UY.png) Was thanked: 830 time(s) in 526 post(s)
Originally Posted by: Matteo_94 ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) Hi,
Thank you
Hi. sigma.c fucntion is defined with an if clause. SMath can't integrate it, but you can use cases(): ![Clipboard01.jpg](/forum/resource.ashx?a=37100&b=2) Now you can integrate: ![Clipboard02.jpg](/forum/resource.ashx?a=37101&b=2) Best regards. Alvaro.
Thanks Alvaro. I made your correction, using the function cases(), but I have the same problem if I add other terms to fb(xn), for example if I add Ast*sigma sb(eps) and Asc*sigmasb(eps). How is it possible? Thanks verifica a flessione_prova2.sm (44kb) downloaded 5 time(s).![Cattura.PNG](/forum/resource.ashx?a=37165&b=2)
![fedeghi fedeghi](/forum/resource.ashx?url=http%3a%2f%2fen.smath.com%2fforum%2fUploads%2f2922.png&width=100&height=100) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 14/09/2013(UTC) Posts: 90 ![Italy Italy](/forum/Content/images/flags/IT.png) Was thanked: 24 time(s) in 16 post(s)
Possibly an odd bracket problem? Here appears that Smath is making a group of "y+sigma bla bla" as object for the differential operator So, fb(x) could not be evaluated. ![Immagine 2021-03-30 113047.png](/forum/resource.ashx?a=37166&b=2) I placed some brackets to clearly separate "y" from what follows in the equation, see picture below. It appears that with brackets, fb(x) can be evaluated (but I get an error on units). Maybe some other formula needs to be checked before? ![Immagine 2021-03-30 113139.png](/forum/resource.ashx?a=37167&b=2) Ciao! Edited by user 30 March 2021 12:44:22(UTC)
Splitted the equation in three contributions, it appears the the integral is not consistent with other two terms of the sum I think calculation should work, once you clear the unit issue which is hidden somewhere in other parts of the calculation. ![Immagine 2021-03-30 115153.png](/forum/resource.ashx?a=37168&b=2) Ciao
![overlord overlord](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 23/07/2013(UTC) Posts: 1,129 ![Turkey Turkey](/forum/Content/images/flags/TR.png) Was thanked: 510 time(s) in 340 post(s)
I am pretty sure my units mismatch correction is not suitable. You should have to check this issue by yourself. But I had managed to solve your function problem. Rewriting it make function tick again. Regards verifica a flessione_prova2_rev.sm (46kb) downloaded 16 time(s).![2021-03-30_14-00.png](/forum/resource.ashx?a=37170&b=2)
![Davide Carpi Davide Carpi](/forum/resource.ashx?u=1544) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,654 ![Man Man](/forum/Themes/yafvision/male.gif) ![Italy Italy](/forum/Content/images/flags/IT.png) Location: Italy Was thanked: 1340 time(s) in 879 post(s)
I've had this pending in background so I'll share the solution even here. Aside the initial issues about if() and units, the integral fails when x_n is set as 0, since epsilon is something/0. Therefore solve range must exclude 0 or the function has to handle it. ![2021-04-03 13_04_33-Window.png](/forum/resource.ashx?a=37193&b=2) Happy Easter and take care, anyone. Edited by user 03 April 2021 14:11:18(UTC)
![Jean Giraud Jean Giraud](/forum/resource.ashx?url=http%3a%2f%2fen.smath.info%2fforum%2fUploads%2f9678.PNG&width=100&height=100) Rank: Guest
Joined: 04/07/2015(UTC) Posts: 6,866 ![Canada Canada](/forum/Content/images/flags/CA.png) Was thanked: 981 time(s) in 809 post(s)
Originally Posted by: Davide Carpi ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) Happy Easter and take care, anyone. Thanks Davide ... Your's all too ... Jean
SMath Studio Forum
Questions
