Offline Matteo_94
#1 Posted : 26 March 2021 12:59:33(UTC)
Matteo_94
can someone help me to copy this mathcad code in a SMath's one?
I have some problems with the solution of Xn
Thank you
Offline Matteo_94
#2 Posted : 26 March 2021 16:09:07(UTC)
Matteo_94
ok,
thanks
verifica a flessione_prova.sm (44kb) downloaded 10 time(s).
Offline Razonar
#3 Posted : 26 March 2021 18:52:12(UTC)
Razonar
Uruguay
Was thanked: 830 time(s) in 526 post(s)
Thank you
Hi. sigma.c fucntion is defined with an if clause. SMath can't integrate it, but you can use cases():
Now you can integrate:
Offline Matteo_94
#4 Posted : 30 March 2021 10:10:19(UTC)
Matteo_94
Thanks Alvaro.
I made your correction, using the function cases(), but I have the same problem if I add other terms to fb(xn), for example if I add Ast*sigma sb(eps) and Asc*sigmasb(eps).
How is it possible?
Thanks verifica a flessione_prova2.sm (44kb) downloaded 5 time(s).
Offline fedeghi
#5 Posted : 30 March 2021 12:37:01(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
Possibly an odd bracket problem?
Here appears that Smath is making a group of "y+sigma bla bla" as object for the differential operator
So, fb(x) could not be evaluated.
I placed some brackets to clearly separate "y" from what follows in the equation, see picture below.
It appears that with brackets, fb(x) can be evaluated (but I get an error on units).
Maybe some other formula needs to be checked before?
Ciao!
Edited by user 30 March 2021 12:44:22(UTC)  | Reason: Not specified
Offline fedeghi
#6 Posted : 30 March 2021 12:54:56(UTC)
fedeghi
Splitted the equation in three contributions, it appears the the integral is not consistent with other two terms of the sum
I think calculation should work, once you clear the unit issue which is hidden somewhere in other parts of the calculation.
Ciao
Offline overlord
#7 Posted : 30 March 2021 14:03:34(UTC)
Turkey
I am pretty sure my units mismatch correction is not suitable.
You should have to check this issue by yourself.
But I had managed to solve your function problem.
Rewriting it make function tick again.
verifica a flessione_prova2_rev.sm (46kb) downloaded 16 time(s).
#8 Posted : 03 April 2021 14:06:31(UTC)
I've had this pending in background so I'll share the solution even here. Aside the initial issues about if() and units, the integral fails when x_n is set as 0, since epsilon is something/0. Therefore solve range must exclude 0 or the function has to handle it.
Happy Easter and take care, anyone.
Edited by user 03 April 2021 14:11:18(UTC)  | Reason: Not specified
#9 Posted : 04 April 2021 00:45:13(UTC)
Thanks Davide ... Your's all too ... Jean
