Offline hawe
#1 Posted : 19 April 2020 14:24:42(UTC)
hawe
Was thanked: 3 time(s) in 2 post(s)
Hallo zusammen,
DimEigenraum: (n-rank(A-λ*E))=1@#
should be 2
some steps of elementary row additions later
is 2
https://de.smath.com/cloud/sheet/vooDFR4FbP
any idea whats wrong?
#2 Posted : 19 April 2020 16:08:10(UTC)
This link doesn't works, be sure to use the share button link (on the right of the save button), because the address bar link is restricted to the author only.
Offline hawe
#3 Posted : 19 April 2020 16:19:42(UTC)
hawe
Upps, sorry
Made a link
https://de.smath.com/cloud/worksheet/3BgYDE7e,
Maxima pure
(%i6) A: matrix([1,1,1,-1,0],[0,1,0,0,1],[0,0,0,1,0],[0,0,-1,2,1],[0,0,0,0,1])$
(%i7) A-1*ident(5)$
(%i5) rank(A-1*ident(5));
(%o5) 3
but
Maxima(rank(A-1*identity(5)))=4
or
#4 Posted : 19 April 2020 19:37:27(UTC)
The referenced sheet seems to use Maxima(). This doesn't work, as third party plug-ins aren't available in the cloud version.
It is better to attach such files here.
#5 Posted : 19 April 2020 19:50:54(UTC)
rank(M) ... matrix rank is Smath built-in.
Here is a most precious application.
Matrix PseudoInverse.sm (112kb) downloaded 9 time(s).
Offline hawe
#6 Posted : 19 April 2020 20:09:48(UTC)
hawe
and in how far do your example explain the incorrect calculation
the Maxima part calculate the single eigenvalue which is set manually in cloud version
SMath Studio 0.99.6884 - [JordanMatrix5x5-5fachEW-HV.1.2.Stufe.sm_]_2020-04-19_19-07-08.jpg
JordanMatrix5x5-5fachEW-HV.1.2.Stufe .sm (48kb) downloaded 12 time(s).
Edited by user 20 April 2020 00:59:39(UTC)  | Reason: Not specified
Offline Razonar
#7 Posted : 20 April 2020 05:51:44(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi. You're right, it's a bug and there are no way to make this works (numerical nor symbolic):
First column is zero and 3th = - 4th columns, so can't be rank = 4.
#8 Posted : 20 April 2020 17:51:33(UTC)
Just advanced maths above the classroom.
Your example replies bug from incorrectly threaded input.
As given, your [5*5] matrix has no mathematical meaning.
Page1 rank.sm (12kb) downloaded 15 time(s).
on 20/04/2020(UTC)
#9 Posted : 20 April 2020 20:19:49(UTC)
... clean the bugger
What application do you have for "rank(,) ?
Don't confuse with Rank in Data Analysis.
rref [Row Reduce Echelon Function] is a damned long monkey business.
Has it been done in Smath ... Watson ?
#10 Posted : 20 April 2020 20:51:32(UTC)
... Rank(V)
Given a set of data values, the rank of each value is the position
at which that value appears in a sorted list of the data.
When values repeat, the rank is an average of the indices where
the value occurs after sorting.
Similar Topics
Thermal efficiency of an ideal Rankine cycle on superheated steam (Samples)
by OchkovVF 16/04/2024 04:23:59(UTC)
Hips and Bums ௹₩]” 0614776705 ₩௹]” Enlargement Pills,Injection for sale in Frankfort (Samples)
by Guest 01/12/2023 05:51:36(UTC)
Ideal Rankine cycle (Samples)
by OchkovVF 15/05/2023 19:56:26(UTC)
Drank by dividing the carbonated (Questions)
by cunchu 14/12/2013 08:21:21(UTC)
Incorrect values for rank (Bugs & Problems)
by Ward.Holloway 21/02/2013 17:57:28(UTC)
rank() needs Numerical optimization! (Bugs & Problems)
by omorr 13/02/2012 23:52:16(UTC)
