8 Pages«<45678>
Offline ElSid
#101 Posted : 15 April 2016 23:58:09(UTC)
ElSid
United States
Originally Posted by: ElSid Go to Quoted Post
Using Jean's files in the same directory, I updated to Mike's sheet and compared it to UNI's pdf ... I still have an error in the re-definition of BETA. Using latest SMath and plugins.
This is on my work computer ... not the one at home.
BTW, I tried with both files on my desktop and in the "C" drive.
Edited by user 16 April 2016 00:08:35(UTC)  | Reason: Not specified
#102 Posted : 16 April 2016 01:43:19(UTC)
... just like this
Offline ElSid
#103 Posted : 16 April 2016 05:43:26(UTC)
ElSid
United States
Not that BETA ... the one to the right of "FIT" per my screenshot. Everything up to that point matches UNI's PDF. I've tried moving the "BETA" down. I think that is why I have red boxes below.
Offline уни
#104 Posted : 16 April 2016 06:10:09(UTC)
уни
βNlin() redefined (βNlin() := include() = 4).
Offline resist
#105 Posted : 25 July 2017 16:59:19(UTC)
resist
Hungary
Hi!
Access to Windows Enviroment Variables would be really nice:
Code:
include("%SM_INCLUDE%\fn.sm")=10
Do you think it's possible?
Thank you
Offline uni
#106 Posted : 26 July 2017 08:31:54(UTC)
uni
Yes, it is possible. Will be in new release.
Russia ☭ forever
Viacheslav N. Mezentsev
on 26/07/2017(UTC),  on 26/07/2017(UTC)
Offline resist
#107 Posted : 26 July 2017 13:19:07(UTC)
resist
Hungary
Awsome! Thank you! Good
Offline uni
#108 Posted : 05 September 2017 10:52:41(UTC)
uni
Updated (for SMath Studio 0.98.6437).
Russia ☭ forever
on 05/09/2017(UTC),  on 06/09/2017(UTC)
Offline MarB
#109 Posted : 11 November 2018 12:06:36(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
Hi!
I updated to SMath Version 0.99.6884.
Include() cannot read Sheets saved with this SMath Version. The result looks like include(...)=0.
By examining the files I found the new worksheet tag. And the regions tag moved downwards.
after saving with 0.99.6884:
Code:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<?application progid="SMath Studio Desktop" version="0.99.6884.37264"?>
<worksheet xmlns="http://smath.info/schemas/worksheet/1.0">
  <settings dpi="96">
    <shortcut>Formelsammlung</shortcut>
    <identity>
      <id>5f168c43-3307-422f-ab94-2a3c16977117</id>
      <revision>775</revision>
Code:
    </dependencies>
  </settings>
  <regions type="content">
    <region id="0" left="567" top="0" width="104" height="215" color="#000000" bgColor="#ffffff" fontSize="10">
      <math>
Maybe that's the reason?
thanks 1 user thanked MarB for this useful post.
on 13/11/2018(UTC)
Offline RFreund
#110 Posted : 11 November 2018 17:43:47(UTC)
RFreund
United States
I'm having the same issues.
Offline uni
#111 Posted : 13 November 2018 13:41:52(UTC)
uni
Updated (plugin version changed to 0.2.x.x). Try now.
Old worksheets must be saved in the new format.
Edited by user 13 November 2018 13:46:47(UTC)  | Reason: Not specified
Russia ☭ forever
Offline MarB
#112 Posted : 22 February 2019 13:44:06(UTC)
MarB
found a little bug in include():
Strings containing only one space " " are imported as an empty string.
on 22/02/2019(UTC)
Offline uni
#113 Posted : 22 February 2019 14:40:39(UTC)
uni
Updated. Try now.
Russia ☭ forever
on 22/02/2019(UTC)
Offline MarB
#114 Posted : 22 February 2019 15:00:54(UTC)
MarB
What a quick answer!
I forgot to mention, that I use the latest stable 0.99.6884.
As the plugin is not offered through the plugins dialog, I downloaded the latest file directly and replaced the current one.
But that doesn't work:
Online Davide Carpi
#115 Posted : 22 February 2019 16:20:27(UTC)
Was thanked: 1332 time(s) in 876 post(s)
The plugin was compiled for a more recent SMath Studio, that's why you can't get it through the extensions manager and why you get the error message (in short the library rely on a different interface than the one available in your version, they can't talk each other)
Edited by user 22 February 2019 16:25:13(UTC)  | Reason: Not specified
Offline MarB
#116 Posted : 22 February 2019 19:21:17(UTC)
MarB
Updated. Try now.
Is working, with 0.99.6988
Thanks a lot.
Could you update the plugin for the latest stable, please?
Edit:
I have a more comprehensive sheet, which I include:
now (0.99.6988 with updated include extension) the result of include is shown as usual (98 elements), but they are not accessible:
At first start a few equations were present, but finally I can't get it to work.
I can't even say, if the beta Smath app or if the extension is making troubles.
The old extension 0.2.6982.28030 works correctly, apart from " ".
Edited by user 22 February 2019 20:54:41(UTC)  | Reason: Not specified
Offline uni
#117 Posted : 23 February 2019 04:14:45(UTC)
uni
Updated. Added support for 0.99.6884.
Show me .log file from the plugin directory.
Russia ☭ forever
Offline MarB
#118 Posted : 23 February 2019 16:56:29(UTC)
MarB
Here you are:
Code:
23.02.2019 14:51:58 [ERROR] Das Objekt des Typs "System.Xml.XmlWhitespace" kann nicht in Typ "System.Xml.XmlElement" umgewandelt werden.
>The object of type ... cannot be converted to ...<
Offline Razonar
#119 Posted : 23 February 2019 19:10:39(UTC)
Razonar
Uruguay
Hi. Related, but in SMath:
on 24/02/2019(UTC)
Offline uni
#120 Posted : 24 February 2019 03:24:05(UTC)
uni
Updated. Try now.
Russia ☭ forever
on 24/02/2019(UTC)
Similar Topics
Display formula stored in "Included" SMath file (Questions)
by faruk 10/03/2024 23:36:28(UTC)
include files @ startup (Questions)
by charlamb 10/05/2023 23:44:05(UTC)
Adidas include guaranteed with the 12 months (Bugs & Problems)
by Guest 11/12/2020 07:02:55(UTC)
include function issues (Questions)
by jrufener 01/06/2019 21:44:47(UTC)
[include plugin] missing LinqBridge.dll error in SMath Viewer executables (Bugs & Problems)
by resist 24/11/2017 18:07:37(UTC)
Include [User Program Function] (Feature Requests)
by Jean Giraud 16/04/2016 15:29:14(UTC)
"include" plugin: default directory setting (Feature Requests)
by mikekaganski 04/04/2016 07:19:58(UTC)
Include and Combobox Region (Questions)
by RFreund 01/03/2016 02:18:21(UTC)
include does not seem to work anymore (Bugs & Problems)
by Tinu 23/06/2014 09:56:03(UTC)
Even so Kobe Shoes includes by no means offered " up " their particular method to Nike Air condition (Questions)
by gladys 07/06/2014 05:27:07(UTC)
Include Hook Sections (Feature Requests)
by sublim21 29/05/2013 21:23:33(UTC)
Include ksi and ksf in next release (Feature Requests)
by TheWizEd 17/07/2010 22:42:11(UTC)
Include function (Feature Requests)
by LordMike 24/10/2009 05:15:45(UTC)
8 Pages«<45678>
