Originally Posted by: ElSid Using Jean's files in the same directory, I updated to Mike's sheet and compared it to UNI's pdf ... I still have an error in the re-definition of BETA. Using latest SMath and plugins. This is on my work computer ... not the one at home. BTW, I tried with both files on my desktop and in the "C" drive. Edited by user 16 April 2016 00:08:35(UTC)
... just like this
Originally Posted by: ElSid Not that BETA ... the one to the right of "FIT" per my screenshot. Everything up to that point matches UNI's PDF. I've tried moving the "BETA" down. I think that is why I have red boxes below.
βNlin() redefined (βNlin() := include() = 4).
Hi! Access to Windows Enviroment Variables would be really nice: Code:include("%SM_INCLUDE%\fn.sm")=10
Do you think it's possible? Thank you
Originally Posted by: resist Do you think it's possible?
Yes, it is possible. Will be in new release. |
on 26/07/2017(UTC), on 26/07/2017(UTC)
Awsome! Thank you! Originally Posted by: uni Originally Posted by: resist Do you think it's possible?
Updated (for SMath Studio 0.98.6437). |
on 05/09/2017(UTC), on 06/09/2017(UTC)
Was thanked: 21 time(s) in 17 post(s)
Hi! I updated to SMath Version 0.99.6884. Include() cannot read Sheets saved with this SMath Version. The result looks like include(...)=0. By examining the files I found the new worksheet tag. And the regions tag moved downwards. after saving with 0.99.6884: Code:<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<?application progid="SMath Studio Desktop" version="0.99.6884.37264"?>
<worksheet xmlns="http://smath.info/schemas/worksheet/1.0">
<settings dpi="96">
<shortcut>Formelsammlung</shortcut>
<identity>
<id>5f168c43-3307-422f-ab94-2a3c16977117</id>
<revision>775</revision>
Code: </dependencies>
</settings>
<regions type="content">
<region id="0" left="567" top="0" width="104" height="215" color="#000000" bgColor="#ffffff" fontSize="10">
<math>
Maybe that's the reason?
1 user thanked MarB for this useful post.
I'm having the same issues.
Originally Posted by: MarB By examining the files I found the new worksheet tag. And the regions tag moved downwards. Updated (plugin version changed to 0.2.x.x). Try now. Old worksheets must be saved in the new format. Edited by user 13 November 2018 13:46:47(UTC)
Hi, found a little bug in include(): Strings containing only one space " " are imported as an empty string.
What a quick answer! I forgot to mention, that I use the latest stable 0.99.6884. As the plugin is not offered through the plugins dialog, I downloaded the latest file directly and replaced the current one. But that doesn't work:
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1332 time(s) in 876 post(s)
Originally Posted by: MarB I use the latest stable 0.99.6884.
As the plugin is not offered through the plugins dialog, I downloaded the latest file directly and replaced the current one. But that doesn't work: The plugin was compiled for a more recent SMath Studio, that's why you can't get it through the extensions manager and why you get the error message (in short the library rely on a different interface than the one available in your version, they can't talk each other) Edited by user 22 February 2019 16:25:13(UTC)
Originally Posted by: uni Updated. Try now. Is working, with 0.99.6988 Thanks a lot. Could you update the plugin for the latest stable, please? Edit: I have a more comprehensive sheet, which I include: now (0.99.6988 with updated include extension) the result of include is shown as usual (98 elements), but they are not accessible: At first start a few equations were present, but finally I can't get it to work. I can't even say, if the beta Smath app or if the extension is making troubles. The old extension 0.2.6982.28030 works correctly, apart from " ". Edited by user 22 February 2019 20:54:41(UTC)
Updated. Added support for 0.99.6884. Originally Posted by: MarB I have a more comprehensive sheet, which I include: now (0.99.6988 with updated include extension) the result of include is shown as usual (98 elements), but they are not accessible: At first start a few equations were present, but finally I can't get it to work. I can't even say, if the beta Smath app or if the extension is making troubles. Show me .log file from the plugin directory. |
Originally Posted by: uni Updated. Added support for 0.99.6884. Show me .log file from the plugin directory. Here you are: Code:
23.02.2019 14:51:58 [ERROR] Das Objekt des Typs "System.Xml.XmlWhitespace" kann nicht in Typ "System.Xml.XmlElement" umgewandelt werden.
>The object of type ... cannot be converted to ...<
Originally Posted by: MarB Hi, found a little bug in include(): Strings containing only one space " " are imported as an empty string. Hi. Related, but in SMath: Best regards. Alvaro.
